586,036 active members*
4,109 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Program getting stuck sometimes?
    Hey everyone, hope you are all doing great.
    I’m having an issue where I will run a program and it will run fine for maybe 1 run, maybe 20 runs. Sooner or later it will get stuck on line 3 and never do anything. If I stop the program and reload it, it won’t work. The only way to get it working again is to reload Mach 3.
    I’m calling the gcode that bobcad gives me a “program”.
    If it gets stuck on line 3, the status will usually say which end mill I’m using. If I just hit start run again like I would if I changed tools, nothing happens.
    I’m not really sure what’s going on. Any help or advice is greatly appreciated.
    Mar 2012
    1570
    Re: Program getting stuck sometimes?
    Not sure this is a BobCAD issue, I would recommend hitting up the mach group and see what those guys say.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Quote Originally Posted by aldepoalo View Post
    Ok, thank you.
    Al is spot on here, if your program runs OK a couple of times then there is noting wrong with the code, it's your controller that's causing the issue.
  1. program of tab program in mori sv 400 and program tool chance
    By hmtam1311 in forum Mori Seiki Mills
    Last Post: 12-10-2017, 02:54 PM
  2. Stuck in the 90's
    By Mastercam3stuck in forum Community Club House
    Last Post: 10-08-2013, 10:01 PM
  3. TNC 310 program gets stuck after spindle start
    By danielhermle in forum HEIDENHAIN -> TNC
    Last Post: 10-02-2011, 01:14 PM
  4. stuck ram
    By RP Designs in forum Uncategorised MetalWorking Machines
    Last Post: 02-05-2010, 06:44 AM
