586,104 active members*
3,331 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > HARD DRIVE MAPPING---Where do the files go???
Results 1 to 3 of 3
    Jan 2012
    15
    2010 TM-2.
    It has the Ethernet option and I have set it up to successfully interact with a NAS share.
    I also set up its own internal "ACCESS TO CNC SHARE" as "FULL" and can see it from my computer as (\\hhas-tm2).
    From my computer, I can send files to it, edit them, rename them, etc (full access is turned on)
    HOWEVER
    I cannot see where the hell the files actually ARE on the mill!
    I have:
    "HARD DRIVE TAB ENABLED" set to ON but cannot see the HARD DRIVE tab.
    I have:
    "ENABLE HARD DRIVE" set to 1.
    I looked as best as I could inside the control cabinet but could not find a hard drive (obviously it could be hidden).
    The files are getting stored SOMEWHERE (presumably on a hard drive...).
    I have searched through the forums and all over the Googles, and cannot find info on this.
    Anyone have any ideas?
    Thanks.
    Aug 2009
    1573
    Re: HARD DRIVE MAPPING---Where do the files go???
    does this help ya...see something about "Remote Net Share Enabled"
    https://staging-diy.haascnc.com/net-share-settings
    Jan 2012
    15
    Ok figured it out, thanks.
    Although I had SHOW HARD DRIVE TAB enabled, I actually did NOT have HARD DRIVE ENABLED set to "1".
    That did the trick.
  1. new hard drive with dolphin on the slave drive question
    By turbothis in forum Dolphin CAD/CAM
    Last Post: 06-13-2015, 08:53 PM
  2. Vf11 Delete files off Hard drive
    By Ron22 in forum Haas Mills
    Last Post: 08-05-2014, 07:42 PM
  3. Replies: 1
    Last Post: 05-30-2013, 05:53 PM
  4. DX32 hard drive (DOM Flash thumb drive) replacement procedures. WIP
    By Cellar Dweller in forum Bridgeport / Hardinge Mills
    Last Post: 01-06-2012, 05:26 AM
  5. HAAS VF3 hard drive or no hard drive
    By teal854t in forum Haas Mills
    Last Post: 08-18-2010, 03:27 PM
