586,113 active members*
3,071 visitors online*
Results 1 to 6 of 6
    Oct 2019
    19
    Bridgeport EZ Trak DX Series 1
    Good day all.
    I have recently purchased a Bridgeport EZ Trak DX Series 1 milling machine with 2 Axis control for my personal use from an Auction in UK and have it delivered to my house in Cyprus.
    Unfortunately it was delivered without any manuals. The only document I have is an A4 pg mentioning only the machine Serial No (720434) and the control No (EZ 2767). Also mentioned the date of delivery Nov 96.
    Anyone has the manuals PDF format that can send it over to me.
    VBR
    Nikos
    Mar 2020
    6
    Re: Bridgeport EZ Trak DX Series 1
    Apr 2020
    Oct 2019
    19
    Hi
    Thanks for the manual.
    now is up and running.
    I had to connect a keyboard in order to restart the machine.
    once more Thanks.
    Aug 2009
    1573
    ...Congrats on new (to you) machine. also, might be a good Idea to backup control Parameters, HDD etc....asap.
    DJ
    Oct 2019
    19
    Quote Originally Posted by machinehop5 View Post
    DJ
    Hi DJ.
    I am trying to set the floppy drive in operation but is not working.
    I have also installed another floppy drive but results are the same.
    I have check the power from power supply and it's ok.
    It might be the controller card or the grey cable.
    I need to check further.
    If I manage to backup parameters, can I install the program on a Pentium 4 computer and be able to write the program from desk?
    If not any idea how can do it?
    What program I need and in case if floppy drive is not working how can I transfer the program?
    Br
    Nikos
  1. Bridgeport EZ Trak Series 1 Axis Motion
    By DKochGA in forum Bridgeport / Hardinge Mills
    Last Post: 08-21-2017, 02:50 PM
  2. Want to import DXF on EZ Trak Series 1
    By tmjewett in forum Bridgeport / Hardinge Mills
    Last Post: 01-19-2016, 12:52 AM
  3. NEED BRIDGEPORT SERIES ONE EZ TRAK WIRING DIAGRAM
    By Korellibopper in forum Bridgeport / Hardinge Mills
    Last Post: 12-04-2011, 05:30 PM
  4. EZ-TRAK Series 2
    By Holzwurm56 in forum Bridgeport / Hardinge Mills
    Last Post: 01-10-2011, 12:19 PM
  5. 1997 Bridgeport EZ-TRAK SERIES 1 DX
    By tdr1985 in forum Bridgeport / Hardinge Mills
    Last Post: 10-22-2010, 03:43 PM
