586,055 active members*
4,291 visitors online*
Results 1 to 2 of 2
    Mar 2013
    47
    Question 20CrMnTi welding shaft build up
    Hi guys !
    I need to build up a splined shaft from 52mm(top of spline is 60mm) up to 70mm O.D over a length of about 110mm then, anneal it, bore it 50mm I.D, turn it, carburize it, heat treat it and grind it for a bearing fit... 20CrMnTi Material is close to SAE3115 or 20MnCr5.
    I have an AC stick welder and my welding buddy is a TIG welder by trade..
    What welding/filler rod should I use for this job ?
    Thanks very much !
    Mar 2013
    47
    Re: 20CrMnTi welding shaft build up
    Up !!!
  1. Replies: 2
    Last Post: 07-31-2018, 05:08 AM
  2. Dual Shaft NEMA34 Stepper Motor Sale....but I only need single shaft.
    By jerseyguy1996 in forum Stepper Motors / Drives
    Last Post: 11-25-2014, 09:25 PM
  3. Replies: 0
    Last Post: 11-24-2014, 05:43 PM
  4. TIG welding Steel/Iron welding with Argon?
    By Rich05 in forum Welding Brazing Soldering Sealing
    Last Post: 12-02-2007, 02:11 AM
