I have a 5hp
www.cedarberg.com on my s1 R2V3. Was the one they recomended in their PDF of part numbers 5HP heavy duty. Has caps and stuff already built in. Seems to run nice. Pretty quiet (hum). Pretty large. Wish it was a sealed unit like some are but it's mounted in my basement to one of the over head I beams so it stays out of dust and stuff for the most part. was nearly crushed mounting it in the cage I made (lifting it up) but hay..
THings I don't like.. It's not soft start, Has a start mode switch that has to be on before power is applied then turned off. Kinda a pain. If the switch is not in the "On" possition you will blow a breaker or fuse. But I have not done that yet (except for the first time I powered it up)..
Kinda on the expencive side as well got it from the local Production tool.
b.
