586,069 active members*
3,820 visitors online*
    Oct 2019
    4
    Heidenhain LE410CA
    I have cincinNati arrow 1000,fixed with HeidenhainLE410CA controller,i have 2 issue,first need parameter,and second the lcd display faulty,i use a pc monitor with x23 mgaport,but it'snot showing correctly,awaiting reply
    Sep 2009
    99
    Re: Heidenhain LE410CA
    Have you been able to resolve your issue?
    I might be able help with the display issue- however for the parameters you would probably need to see if the machine came with floppies/CD or if anyone else has a similar machine from which you could copy the backup.
    Are you sure all the parameters are gone?
    best regards
    Jaideep
