I'm selling my PM-932 CNC mill so I can move up to a industrial level machine. If you are looking for a turn key CNC mill loaded with options this is the one for you.
Precision Mathews PM-932 milling machine purchased new
Column stiffening mods
WJ200 Hitachi VFD with 2HP Marathon Black Max Inverter Duty Motor
Two speed belt drive spindle conversion with angular contact bearings (8500 RPM max speed)
PMDX-126 breakout board, PMDX-107 spindle control board, Warp9 ethernet smooth stepper
Nema 34 stepper motor with dual shafts on X and Y axis, 1600 oz-in holding torque
Nema 42 stepper motor with single shaft on Z axis, 4200 oz-in holding torque
DQ860MA/7.8A stepper drivers on X and Y axis
DQ2272/8.0A peak current, 7.0A rated current stepper driver/power supply on Z axis
350W, 60VDC, 5.9A power supply for X and Y axis
Rollaway with AC power system components located in bottom drawer
Licensed copy of Mach3, CamBam and D2NC
Laptop computer running Windows7 64 bit, monitor, keyboard and mouse
Braking resistor to allow for power tapping
1605 ball screws and double ball nuts on X and Y axis
2005 ball screw and double ball nut on Z axis
Z axis ball nut carrier mod to minimize backlash
Extended X and Y axis travel
One shot lube system
Full enclosure with overhead lighting
Flood coolant system including reservoir, pump, spare pump, filter and oil skimmer
2010 screen set with fixed tool setting plate
Ultron Snap Change tool changer and tool holders only. Cutters, drill bits and and other cutting or measuring devices are not included
Auxiliary high speed spindle (24000 rpm) with PID controller
Z axis tool setter
X, Y, and Z axis limit and home switches
All equipment manuals, configuration instructions, and notes included
Manual mill components removed for the CNC conversion included
