586,069 active members*
3,403 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > First time getting a Cobra 42 to run, spindle does not run
Results 1 to 7 of 7
    Jan 2006
    22
    I have a new to me Cobra 42 that is in very nice condition. I have it powered and starting to work with it.
    The main issue right now is that the spindle does not run when I step through a very basic program. And it does not when in MDI mode either. While running in single block mode the program goes through each step flashing the Cycle Start button light at each block as I push the button for the next block. When it gets to the block for turning on the spindle the button light stays on, the program does not advance, and the spindle does not turn on. No messages nor alarms are displayed. It sits in that mode until I hit the reset key.
    Any ideas?
    The machine was running until the day I picked it up. I have not found anything in the manuals that would lead me in any direction.
    Kevin
    Aug 2009
    1573
    Re: First time getting a Cobra 42 to run, spindle does not run
    Power Down,,,turn off Main Power ..wait for 20 mins to be safe (Cap's Discharge)..start checking Fuses to Spindle drive to start with. Get some photos of the drive may help too. are any LEDs lighting up on drive?. Model # of Drive may help us. Do you have any machine Manuals?
    Jan 2006
    22
    I have attached a couple pictures of the screen and of the controller when in the "stuck" situation. The first picture is of a sample program I am trying to step through. The second is the step where it gets "stuck" trying to control the spindle. And the last picture is of the controller during that step.
    Did I miss something in the controller software? Or is this a hardware issue?
    Attachment 436006
    Attachment 436008
    Attachment 436010
    Dec 2013
    5717
    Your pictures are not viewable.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2006
    22
    Hopefully I fixed that.
    Thanks.
    Dec 2013
    5717
    You might replace your M13 with a M3.
    Jim Dawson
    Sandy, Oregon, USA
    Jan 2006
    22
    Thanks but I already tried that. Along with M4 and M14. They all did the exact same thing, nothing.
  1. Hardinge Cobra 42 spindle drive problem
    By Dsenterfitt in forum Hardinge Lathes
    Last Post: 03-28-2019, 09:57 PM
  2. Spindle bearings cobra 42
    By dresda in forum Hardinge Lathes
    Last Post: 03-20-2019, 09:17 PM
  3. Spindle Run Time
    By Ranji in forum Linear and Rotary Motion
    Last Post: 08-14-2015, 10:00 AM
  4. Cobra 42 Spindle Drive
    By Jtoothman in forum Mini Lathe
    Last Post: 08-04-2014, 06:50 PM
