586,058 active members*
4,249 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma lathe C-acis orientation
Results 1 to 7 of 7
    Feb 2020
    11
    We have an Okuma captain 3 axis lathe. When setting up a part we indicate across a flat on the part and calculate that as being C0. When we run the part the holes we drill on the on are always shifted about 1/4 degree. This shift varies a bit from part to part. So, I put in a C-axis variable shift in the program (VZSHC)to try to align it better. Does anyone know why we might have this alignment problem? We also have the same issue on a 3 axis Samsung lathe with a fanuc control.
    Jun 2015
    4154
    Re: Okuma lathe C-acis orientation
    hy flast, to indicate much faster, you may use a precision level so to orientate the flat in the horizontal phishical plane, then index the C axis with the angle between the X bed and the horizontal plane ( eq30* ), then start to manualy indicate the flat : at this moment, you should need to adjust only 1-2-a few degress
    another way, that may be faster, is by using X axis feed-skip, but i never tried it on an y lathe when y<>0
    is the live tool coaxial with the spindle ?
    write down the values, observe the tendency, then, if you wish check the coaxility / kindly
    ps : if you wish, i can tell you how to also check the tram, but this is not a must for tools with low diameter
    Feb 2011
    353
    one of the reasons might be that when you indicate the part you rotating one way and when the machine goes to c axis mode there is a difference in positioning
    there is also the positioning error to account for (There is positioning accuracy and there is repeatably accuracy)
    you could try and program it to stop at -90 degrees then rotate back to 0 degrees to keep the spindle rotating in one direction
    Jun 2015
    4154
    if machine is in m109, then, when executing m110, it will rotate only in one direction ( thus it is not going always the shortest path ); at the end of this sequence, C axis will be 0 ( this is the common behaviour for lathes, unless changed by parameters )
    after that, when indexing to C<>0, it will always go in one direction ( that may be the shortest path, or not, depending on m15 16 960, etc )
    this way, each C in-position comand is always being achieved by rotating the spindle in a constant direction ( somehow similar to uni-directional-positioning; udp ) ( for example, for a random setup, at 270* is always approaching from 271*, thus from a greater value, but for 10* is always approaching from 9*, thus from a lower value)
    positioning and repetability deviation, are both lower when udp occurs, and they are always within diff-control, and that is << 1/4degrees; even if you use vinpc = 0.9*, cutting will begin at <0.005*, when a normal z-clearance is used / kindly
    Jul 2010
    287
    took the words out of my mouth.
    what you're effectively referring to is backlash in C axis positioning.
    As a test, always rotate the C axis the same direction with the pulse handle to get the flat straight. see if the trend of results improves.
    Jun 2015
    4154
    hello again, i just can't stop thinking about this ... i don't believe that there is backlash, especially because 1/4* means 0.554mm circumference length for the od of a 10" chuck, and that is huge, meaning that the C axis should be used only with the break on during drilling, and it would shake during contouring
    vzshc=1/4*means that there is a missalignment in Y direction; there may also exist a missalignment in X direction, but this one can not be corected by using vzshc, so, for now, let's focus only on Y missalignmnet : for example, if there is 0.1mm Y radial excentricity, and drilling occurs at X50, then it will be required to use a C phase corection of 1/4*, and this sounds pretty realistic
    so far so good ...
    so, deviation is 1/4* + a bit; 1/4* may be from Y missalingment, and 'a bit' may be from the fixture tir ( because the part is re-clamped ) and/or drills buckling/bending, because of wear/length/specs
    kindly
    Jul 2010
    287
    Quote Originally Posted by deadlykitten View Post
    so far so good ...
    kindly
    It is possible that this is a fixturing issue.
    VZSHC would help a Y axis err if the holes were parallel to the Z.
    I still believe it is a backlash during setup issue.
    I have had this issue when setting up to re-machine features on rifle barrels which needed machined in relation to the gas port hole. We indicated across a fixture with a pin in the hole to find C0 for every part.
    Hopefully he finds and shares the answer. I hadn't thought about this again at all until I checked my email and saw the reply notification. Maybe then you can think about something else.
