586,069 active members*
3,471 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > EMCO Lathe > DIY tool presetting for Emco PC turn 105?
    Mar 2019
    15
    I am running a highly modified emco pc turn 105 (Bigger Chuck, moved spindle and tool turret out and down, custom tool holders giving an extra inch reach up and down on X axis.). Running Fusion 360 into Fanuc 21T (the european version, C).
    I'm wondering if its possible to do some kind of tool pre-setting with the Fanuc21t software, and any advice as to how to do it on both the software and physical front.
    Would love something mounted in the machine (haas style) but worry that there isnt a super rigid surface to mount arm to, and worry about repeatability and accuracy. My other idea is to have an isolated disc I can chuck up and check the runout with a dial indicator, adjust and then preset tools., or a variant on that idea would be an isolated cylinder that I slide into the center of the chuck and bolt it tight into the pocket through the spindle (perhaps more repeatability/faster?) Would it even be possible to bootstrap this into the fanuc software?
    Attached is a pic of the larger chuck / tool turret modifications / custom tool holders.
    Re: DIY tool presetting for Emco PC turn 105?
    hey,
    i have also got a EMCO Turn 105.
    (Prototype 1 Serial Number with ACC)
    i am looking for an alternative optical presetting tool.
    for your information, there is a description , how you can set up your tools with a reference piece and touching it.
    feel free to contact
    greetings from germany
  1. How do you do tool height presetting?
    By TTalma in forum DIY CNC Router Table Machines
    Last Post: 05-21-2019, 04:46 AM
  2. WANTED: Emco pc turn 105 tool holders/collets/tooling
    By axefxpwner in forum Want To Buy...Need help!
    Last Post: 04-10-2019, 06:13 PM
  3. Running the tool changer on an Emco Turn 50
    By rstrohl56 in forum Auto Tool Changer
    Last Post: 09-19-2014, 03:50 PM
  4. Problem with Presetting tool
    By Man@Work in forum Daewoo/Doosan
    Last Post: 02-22-2008, 07:31 PM
  5. tool presetting
    By Doug Tyler in forum CNC Tooling
    Last Post: 02-17-2008, 03:29 PM
