I have a MultiCam SF 44 machine with original motherboard and controller. Today I am getting "Z-axis out of bounds" on any job I try to run. The machine homes just fine and also will run a "Dry Run" without fault. If the spindle is turned off it will attempt to start the program but never move past the first slew move. The same program runs fine on my SF48 and programs that worked before do not work now. I have swapped the axis card just in case it was doing something odd and the same fault is happening. Turned the machine OFF and ON a few times also.
