586,058 active members*
4,286 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Need parameters hardinge quest 6/42 build in 2003
Results 1 to 6 of 6
    Apr 2014
    22
    Hello all
    Just bought myself a hardinge quest 6/42 from a auction in Germany.
    It is a ex us army Lathe with only 51 hours on the counter.
    How this thing gets here in Europe I don't have a clue.
    But now it's mine.
    The backup battery is dead so I got a sram error.
    And I only have a manual not a backup.
    Can anyone here provide me with some parameters that might get the machine back working again.
    Thanks in advance.
    Kind regards from Holland
    Aug 2009
    1573
    Re: Need parameters hardinge quest 6/42 build in 2003
    Is it possible someone Stored the Par's on the HDD?
    I see there is more than one Battery also. You didn't say what control you have but, I assume its Fanuc
    http://www.hardingeservice.com/usr/Q...09500-0392.pdf
    Battery replace on pdf page 41
    http://www.hardingeservice.com/usr/Q...09500-0394.pdf
    Apr 2014
    22
    The control is a 21it and does not have a HDD.
    So i'm hoping on some parameters from you guys
    There also might be a problem with the card reader because it won't read the card.
    I have a original Fanuc Compact flash card 128MB.
    I use this in my Hardinge GS250MSY with fanuc 18i control and there it works.
    The machine is 5 years younger so there might be the problem.
    So now i'm also figuring out if the control is the problem or the card.
    I was looking at a post from someone on the internet the early fanuc 21it have problems with reading large Compact flash cards.
    They advice a maximum 16mb Sram compact flash.
    So there is some work more to do, then only get me the parameters.
    May 2016
    526
    I would have thought it was the card reader I'll check my system and private message you
    Apr 2014
    22
    Quote Originally Posted by mbservice View Post
    That would be great I assume you don't try it on a quest Lathe!
    Apr 2014
    22
    Nobody? The machine is build in the USA so this is the right place right!
  1. Hardinge Quest 51 Sub Spindle Alarm
    By pit-bull in forum Hardinge Lathes
    Last Post: 08-17-2011, 04:47 AM
  2. Hardinge Quest 6/42 sub spindle synchronization
    By bschris in forum Hardinge Lathes
    Last Post: 05-01-2010, 07:31 PM
  3. Hardinge Quest 51 Turret Help!
    Last Post: 03-15-2010, 02:29 PM
  4. Need Help With Hardinge Quest 65
    By SDBull16 in forum Fanuc
    Last Post: 04-23-2008, 05:00 PM
