586,281 active members*
4,144 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Is this too much noise? (video)
    Nov 2019
    41
    See video: https://sendvid.com/31cuxuji
    Should my steppers being making this much noise when sitting idle (powered up and linuxCNC on/in control)?
    Jun 2012
    28
    Re: Is this too much noise? (video)
    ANY noise when just sitting idle is too much noise.
    Sorry I don't have any insights into what might be causing it though.
    There are 10 types of people in the world
    Those of us who get binary, and those who don't.
    Nov 2019
    41
    Any noise is bad. Thank you for confirming.
    Anyone have recommendations on how to diagnose causes?
    Nov 2013
    4387
    a stepper driver uses pulse width modulation to regulate the current it supplies to a stepper.
    Have you wondered why it is that you use a 36V (or 48V or......whatever) supply to your driver but is says clearly on the stepper 4.2V?
    Lets make it simple and assume you have a 42V supply. If the driver switches the 42 V to your stepper for 1usec and then off for 9 usec then back on for
    1usec and so on effectively your stepper sees 1/ (1+9) x42=4.2V. So even at idle your driver is switching on and of rapidly. Ideally it would switch fast
    enough that you couldn't tell but if it switches more slowly, say 15,000 times a second then you might detect that as a buzzing sound.
    I am guessing that the sound you are hearing is of that type, and while annoying should cause no problems. The real question is 'do the motors do the
    business when commanded to move?'. Who cares what they do when stopped....its what they do when moving that's more important.
    Craig
  1. 4th axis binding or vibration noise with video!
    By s2jesse in forum Tormach Personal CNC Mill
    Last Post: 01-26-2017, 06:52 AM
  2. Intermittant problem Bridgeport Interact 1 mk2 noise issue - video
    By spookylight in forum Bridgeport / Hardinge Mills
    Last Post: 02-03-2016, 11:36 AM
  3. MV-40B X Axis noise w/ Video
    By blkaplan in forum Mori Seiki Mills
    Last Post: 08-23-2013, 05:24 PM
  4. Stepper noise/vibration video- looking for input
    By Jimdandy in forum Stepper Motors / Drives
    Last Post: 07-02-2013, 07:50 PM
  5. Mystery Spindle Noise (watch video)
    By akedward in forum Haas Mills
    Last Post: 04-19-2009, 05:21 PM
