586,108 active members*
3,256 visitors online*
IndustryArena Forum > CAM Software > MadCAM > "machining_time" not showing the tine?
    Oct 2009
    96
    Joakim,
    "machining_time"
    It does not show a time (see output below), what am I doing wrong?
    Best Regards,
    Mauri.
    *PROGRAM_START*
    (madCAM 5Xtra 4 Axis for Mach4)
    (File Created: "datetime")
    "documentname"
    (Tool Path Profile "method")
    (Tool Number = "toolnr")
    (Tool Offset Number = "tooloffsetnbr")
    (Tool Name = "toolname")
    (Tool List = "cutter_tool_list")
    (Tool Dia = "tool_diameter")
    (Tool Radius = "tool_radius")
    (Tool Radius Compensation = "tool_radius_compensation")
    (Tool Length = "tool_length")
    (TIME/PROGRAM: estimated programtime: = "machining_time")
    (X = "xwidth", Y = "ywidth", Z = "zheight")
    (File Created: 07-Feb-20 4:57:40 AM)
    (Tool Path Profile Planar)
    (Tool Number = 28)
    (Tool Offset Number = )
    (Tool Name = BALL_END_9.525 Roughing .03TT)
    (Tool List = BALL_END_9.525 Roughing .03TT)
    (Tool Dia = 9.525)
    (Tool Radius = 4.762)
    (Tool Radius Compensation = 9.525)
    (Tool Length = 38.000)
    (TIME/PROGRAM: estimated programtime: = )
    (X = 299.878, Y = 89.154, Z = 91.900)
    Oct 2009
    96
    Re: "machining_time" not showing the time?
    Thank you Joakim the time now works with the new update
    Best Regards,
    Mauri.
    (File Created: 18-Feb-20 5:27:31 AM)
    Madonna.3dm
    (Tool Number = 28)
    (Tool Dia = 9.525)
    (TIME/PROGRAM: estimated programtime: = 15 minutes 13 seconds )
    N10 G00 G90 G80 G40 G17 G49 G21 G71 G64 G94
    N11 S15745
    N12 M03
    N13 G01 Z43.740 F2800
    N14 G01 X154.900 Y-4.790
    N15 M06 T28
    N16 G00 X299.996 Y-0.002 A-90.011
    N17 G00 Z13.806
    N18 G00 Z12.845
    N19 G00 Z11.884
    N20 G00 Z9.961
    N21 G00 Z9.000
    N22 G01 X299.983 Y0.009 Z8.992 A-87.542 F1260
    N23 G1 G93 X299.976 Y0.012 Z8.995 A-86.318 F14813
  1. HITEC TURN 25G won't start up and showing "NC UNREADY"
    By sting007 in forum Hitachi Seikis
    Last Post: 04-17-2019, 06:34 PM
  2. Please help.... "%" sign keeps showing up in code
    By 7379df in forum Uncategorised CAM Discussion
    Last Post: 10-31-2017, 03:59 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
