586,655 active members*
2,970 visitors online*
Page 2 of 2 12
Results 21 to 31 of 31
  1. #21
    May 2008
    19
    Re: Homemade fixed gantry build
    More parts arrived . Control box from CNC4PC . Looks good ! I'm getting ahead of the metal work . Cant wait to get the welding and stress relief done .
    Attachment 436652Attachment 436654Attachment 436656Attachment 436658Attachment 436660Attachment 436662
  2. #22
    May 2008
    19
    This is the idea for the Z so far . Carriage started as a 2.5" thick block of 6061 . The ribs will get tapered to the cutting end . Top will get a plate to tie it together and mount the Z servo .
    Dave
    Attachment 436714Attachment 436716Attachment 436718Attachment 436720
  3. #23
    Sep 2018
    6
    It's been a while from last post... any progress ?
  4. #24
    May 2008
    19
    Have not done much lately . trying to not spend extra with all the covid stuff going on .
  5. #25
    Aug 2019
    40
    Quote Originally Posted by dgowland View Post
    Are you installing all the recommended electronics for the DMM drives? That includes: Mains filter, line reactor and EMI filters. Nice build!
    Skickat från min SM-A530F via Tapatalk
  6. #26
    Mar 2017
    411
    Dave
    So, have you thought how you are going to tighten the bolts holding the X axis cars after the X rails are mounted on the gantry?
    I was thinking about it, and normally you would install the rails first so that you can properly align them and then slide the cars on individually and after that mount your Z axis to the cars. It looks like your cars are not threaded and will have to be bolted to the aluminum plate.
    I may not understand, just thinking out loud.
    Bob
  7. #27
    15362
    Quote Originally Posted by maxspongebob View Post
    Bob
    These Linear Bearing Blocks can be fastened just as he has them sitting they can fasten from the top down or any way your design needs for them to be fastened
    Mactec54
  8. #28
    May 2011
    790
    Are those SYK motor mounts?
    I can see you've welded some flat bar where you will mount your rails. I did a similar thing, so I know that they probably aren't very flat right now. It looks like you will weld them onto your gantry as well? What's your plan to machine those?
    Diablo makes great blades. I used to use the Diablo Non-Ferrous blades quite a bit. I may have to try the ferrous one for myself. Cutting big steel with an angle grinder is alot of work, and band saws never seem to cut square. I'm amazed that you can cut half inch steel with a skill saw.
    Is it expensive to get something like this heat treated?
    Nice work.
  9. #29
    15362
    Quote Originally Posted by NIC 77 View Post
    Nice work.
    The stress relieving is not expensive I had 2 plates done 2 weeks ago they where 1" x 8" x 36" cost $12 for the 2 plates the machining can be from $200 to $600 depending on how and what you get done
    Mactec54
  10. #30
    Sep 2018
    6
    Hi!
    Still looking at this thread but no new updates so i'm calling You out @mactec54
    How's Your machine ? Did You make any chips on it ?
  11. #31
    Sep 2018
    6
    Quote Originally Posted by Maxikas View Post
    I mean @dgowland ofc.
    It seems like dgowland was not here since 04-29-2021 08:51 AM (last activity in profile).
Page 2 of 2 12
  1. Fixed Gantry Build
    By UCBones in forum DIY CNC Router Table Machines
    Last Post: 10-20-2020, 11:22 AM
  2. Fixed Gantry CNC build log
    By shoot in forum DIY CNC Router Table Machines
    Last Post: 09-13-2019, 10:22 PM
  3. Fixed Gantry Birch Ply Build
    By Browellr in forum CNC Wood Router Project Log
    Last Post: 01-27-2017, 12:33 AM
  4. New DYI Fixed Gantry Router Build
    By DonFrambach in forum DIY CNC Router Table Machines
    Last Post: 07-06-2015, 12:45 PM
  5. Fixed Gantry - First Build
    By Schweeb in forum DIY CNC Router Table Machines
    Last Post: 04-01-2012, 10:49 PM
