586,117 active members*
3,510 visitors online*
Thread: Tesla
Page 1 of 2 12
Results 1 to 20 of 32
    Sep 2005
    Exclamation Tesla
    The time is now to bring tesla back to life... im not sure what the **** these company's are waiting for but GeoThermal energy alone could save the planet and start a new revolution.
    used oil and gas wells combined with tesla turbines would be enough to start a new revolution
    Nov 2005
    274
    Quote Originally Posted by Unition View Post
    TESLA!!!!!!!!!
    You bet Man I dug there tunes. I been waiting for a Tesla reunion.
    Rock On With Big Fattie, Bluesman
    May 2007
    715
    Nikoli Tesla. Not Tesla the group.
    I still play thiers on the guitar though. :rainfro:
    Apr 2006
    87
    Aren't Tesla Turbines like 35% efficient? I'd think a standard steam turbine would be a lot more efficient.
    Nov 2006
    592
    There's nothing out there stopping anyone from making a Tesla turbine, or a Tesla coil, for that matter.
    The one that mattered the most was the multiphase motor, that sure caught on big time.
    The other innovations have more limited utility.
    Too bad being a genius doesn't guarantee financial success. Interesting man.
    --97T--
    Oct 2004
    118
    He made a RC boat in 1898
    He could send power through the air and rectify it back.
    Thats what the tesla coil was for, when it's throwing sparks its outta tune.
    He's the reason we have A/C in our home's
    Edison is the reason why they have A/C in electric chairs
    Thats the real short list.
    That guy was so far ahead of his time.
    Think it was the wardencliff transmitter , a little EMP problem in colorado and the red scare that made him die in debt.
    His musem is in serbia http://www.tesla-museum.org/meni_en.htm
    Tesla coil ,now thats interesting toy.
    A cool use for old neon sign transformers:rainfro: .
    A wiki link on the turbine:
    http://en.wikipedia.org/wiki/Tesla_t...d_calculations
    Dave
    Jan 2006
    738
    Tesla coil and turbine
    My 6th grade science fair project was a 250KV tesla coil. Would light a flourescent (burnt out even) bulb about 30 ft away. It was a big tuned transformer at about 100 Khz basicly. Also destroyed off air tv and radio reception over quite a range. Definately not good for computer circuitry in the near vicinity either.
    As for the Tesla turbine, here are a couple of links...
    http://www.teslaengine.org/main.html
    http://www.phoenixnavigation.com/
    http://phoenixnavigation.com/ptbc/home.htm
    As for using old oil wells for geothermal, you would want to drill them quite a bit deeper in most cases. California has some geothermal plants in production, but of course they are near the pacific "ring of fire" where thermal energy is available nearer the surface. One test well in austrailia back in 2003 was over 14,000 feet deep. Many older plugged wells are only 2000 ft deep. Just have to look around.
    Steve
    Jun 2006
    440
    Actually there is a company researching this right now. The application is that low voltage appliances, computers cell phones, led/ DC lamps etc will have small receiver coils that pull from a house wide field rather than using transformers to step down AC voltage for each and every charger, light. I read it in popular mechanics at the Dr.'s office the other day, aug edition I believe.
    And you thought it was bad when your neighbor was just hacking into your wi-fi internet connection.
    Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself.
    Mark Twain
    Nov 2006
    114
    I don't pretend to know much about electricity beond basic wireing but, I 've always wonderd if you took the very high voltage and almost no amperage out put of a Tesla coil and turned it around ( by Omes law?) to reduce the the voltage and give a more useable amperage (as is done in a typicle arc welder) ??
    I have seen kits in old Edmund Scientific catalogs that help build hand crank or wind powerd static electricity generators and I have often wonderd if there was a usefull application for somthing that produced this type of electricity beond running your gas engines or shocking the cat. I'm sure I'm mixing up a few diferent devices or terminologies here but you must see the point of my question. I simply want to know if I can extract a supply of usable electricity from these so called static electricity generators?
    Jul 2005
    12177
    It is not ohms law; that is the law that relates voltage, resistance and current. What you are thinking about is using a transformer with an incredibly high primary voltage at a low current and a low secondary voltage at a higher current.
    The problem is in static electricity the current is sooooo low; such as fractions of a microamp. You might have megavolts but power is voltage multiplied by current and a megavolt multiplied by a microamp is 1 watt.
    Of course if you want to get carried away you can use Mother Nature's static electricity, lightening. that comes in megavolts and hundreds, or even thousands, of amps so the wattage can be spectacular. But it doesn't last for very long; fortunately .
    Oct 2004
    118
    Tesla's whole thing was the wireless transmission of power.
    Think he was doing 30 miles and lighting light bulbs.(colorado ?)
    Rectifying and converting the EMP (wave) to a useable level.
    When a tesla coil is throwing sparks its out of tune .
    Jan 2006
    738
    Tesla and tuning
    Debogus,
    Actually the sparks will be there if the "radiator" or "antenna" is out of tune. If you took a 130 Khz Tesla and connected it to a 1/4 wave whip it would most likely not throw sparks.
    Nov 2006
    114
    Thanks for the reply Geof, I begin to see the depths of my madness.
    I have asked this same question of a couple of electricly knowlagable people that could not give me a saticfactory answer. I wonder if you would be willing to explain, in laymens terms, why a typical gen set that is producing useable power requires the motive power that it needs to produce the electricity yet if I mearly wipe my hand across a synthetic carpet I can also produce a certain amount of electricity, given that it has no real use other than to annoy the cat.
    In short, what is it about the production of amperage that requires so much effort to create it?
    Again thanks for the reply from bothe Geof and debogus
    Oct 2004
    118
    Cruise the Tesla forums and sites.
    Tons of info of what and why .
    Mostly those guy's are into making sparks but on that path you will find some history and what Tesla was up to.
    He even thought he could use the coil as a weapon, by directing the energy.
    But alas after a few law suits and the red scare ( and the fact that he was so far ahead of his time didn't help )he died penny less.
    He did R/C first before 1900, that says something .(date on patent list)
    One account I found was Tesla powering a car with wireless power.(not sure of date was a "news" type story from a wittness account)
    I got bit by the bug and built a coil , not hard really.
    That was hobbies ago .
    Now its here and metal casting forums
    Im thinking what he did was more like how they now use microwaves to powerstuff.
    Nov 2006
    114
    hey debogus, thanks for the reply.
    I dig what your saying about "transmitting " power through the air to remotly power a vehicle. That would be astonishing for any day and age not just 1900.
    Now that I have that little kernel of knowlage I will go and check out the material on the Tesla coil from my local library as a start.
    I can imagin there are some serious draw backs to utilizing that kind of power or we would surely be all using it today.
    My first project would be an electric powerd garden tractor to replace the gas one I use to mow my lawn with now, cordless of corse! (no batteries either)
    I think the American use of the lawn mower is a very significant cause of air and niose pollution.
    Jul 2005
    12177
    Quote Originally Posted by merl View Post
    It is just a matter of how much energy you are dealing with. Energy the ability to do work. Work; a force acting through a distance. Such as for instance living a weight of 550 lbs up 1 foot vertically. You are doing work against gravity. I guess maybe 550 is too much; lets make it 157 lbs lifted 3-1/2 feet, I can just barely do that. Lift that weight that distance and you have done 550 foot pounds of work. I deal in the Imperial system because I am too old to reprogram my brain. Now if you lift the weight in one second you have done work at the rate of 1 horsepower. Is this sounding familiar from your high school physics classes? Where your instructor probably said you had to know it for the exam but would never use it again. So where am I going?
    Lets say you want to generate 1500 watts for whatever; some big flood lights on a construction sight maybe. At 100% efficiency 1500 Watts is equal to 2 horsepower but generators are more like 85% efficient, maybe a bit more, so to get the 1500 watts out you need to drive the generator with nearly 2.4 horsepower. But little gasoline or diesel engines are always ovverrated so a 5 hp engine is probably only capable of producing 2-1/2hp in the middle of its rpm range. that is why your 1500 watt generator needs something like a five horse engine driving it.
    Now to the carpet and annoying the cat. How much force to you put into moving your hand across the carpet? Probably not much. How far do you move it? Also not much; so you are not doing much work and you are probably doing it not very fast so the rate at which you are doing work generating static electricity is measured in micro-gnat power . But now we come to the voltage, amperage and resistance thing. Static electricity only builds up on very, very poor conductors, non-conductors really, so even though you are only creating a very small amount of electrical energy it can build up to a very high voltage because the current cannot flow anywhere. Whereas with the genset and lights, the lights are designed to consume their rated 1500watts at 120 volts so that is what the generator puts out.
    I hope this helps. Do you know how difficult it is to compress half of grade eleven physics into a few hundred words?
    Nov 2006
    114
    Geof, I bow deeply to your wisdom and thank you for sharing so freely.
    I do fully understand your answer but,( there is always a catch )this is not exactly what I'm after.
    Let me try to explain a little more of what my thought prosses is here.
    In my mind (wether I'm right or wrong) I see these two forms of electricity, one has a relitivly low voltage ( say 120vac) and a some what higher and more useable amperage of 20amp and all this is contained in a circit in my house.
    the other form of electricity contains a very high voltage of say 10000 volts with a small fraction of a milli amp of amperage, caused by an ion build up on the surface of my skin when I rub the carrpet.
    I know that to make the small lite bulb of a bicycle generator powerd headlamp work takes a noticable amount of leg work and creating enough voltage to jump an 1/8 inch gap with a static electrical charge only requires one to get up out of the arm chair and walk across the floor (usually in stocking feet) to change the TV channle.
    I'm skirting around the old conservation of energy issue (can't get more out of a system than you put into it) because it seems to be working inversly here.
    If I wanted to produce a lot of static electricity for some reason it could be done without much effort or "work" but, we have no apparent use for this type of electricle power. So this is my question again,
    "Why" does it require " X " amount of work input into the system to produce the higher amperages ?
    Some time ago the Univercity of Wisconsin at Madison was involved in a project to develope a means of capturing and storing the electrical energy given off in a typical lightening strike.
    They were going to use a bunch of enormous magnets as a kind of capasitor to capture and hold the charge of later use on the grid.
    Long story short the project was scraped or put on perminent hold because of consern over the heavy magnetic fields effect on miggrating birds.
    So I thought why not try to contain and reuse the power from a much smaller more managable arc? This is were I'm realy going with all these questions.
    BTY, I know the rule as: 1 HP = the effort needed to raise 33,000lbs, one foot (12") in one minets time
    Nov 2006
    114
    To any one else that my be interested, I have another question.
    A few years ago they tried an experiment on the space shuttle to try and extract electricity from the vast amount of ions flying through space.
    The premis was that an electrical current could be collected from a wire of suficient length that was beeing towed through space behind the shuttle craft.
    Aparently it was somthing like a mile or more of rather lite guage wire on a spool to be deployed by a space walk mission.
    The deployment apperatice didn't work right so they only got about 1000 feel of wire out, not enough to be usefull but enough to prove the therory.
    If a Tesla coil could focus its output to a pinpoint spot or a certain earthbound collector and be hooked up to one of these "ion/wire" current producers out in space, would we not have a continuouse supply of power that didn't rely on when the sun is shinning or how hard the wind is blowing?
    Jul 2005
    12177
    ..A few years ago they tried an experiment on the space shuttle to try and extract electricity from the vast amount of ions flying through space.
    The premis was that an electrical current could be collected from a wire of suficient length that was beeing towed through space behind the shuttle craft......
    Yes their deployment failed but their premise was also faulty. Actually the electric current in the wire would have come from it moving in the earth's magnetic field. Yes it is likely that a voltage would develop along the wire but if any current flowed the wire moving through space would have experienced a drag which would have slowed the shuttle and pulled it out of orbit.
    To some extent you are answering your own question when you mention the bicycle generator. When you have it connected in a circuit through a bulb you are doing work on the generator, the energy of your work is converted into electrical energy which lights the bulb, a current is flowing. Open the switch and there is no current flow and you would not have to do so much leg work. If you put a voltmeter across the open switch you would see you are still creating a voltage but because there is no current flow then no energy is being consumed so you are not having to do legwork. The situation is somewhat similar with static electricity; there is no current flow. Remember I mentioned static electricity only builds up on things that are very, very poor conductors, they are insulators. Because there is no current flow the static voltage can build up very high until a spark occurs. Actually you have done a little bit of work building the voltage up but it is so small it is not noticeable. And the spark that occurs does carry current but it is a very small amount of current flowing for a very, very short time. It does not represent much energy, i.e. it does not need much work.
    Nov 2006
    114
    [quote=Geof;377006] Actually the electric current in the wire would have come from it moving in the earth's magnetic field.
    Geof, I seem to recall it beeing described as somthing ahkin to catching the solar winds so that the charged ions passing by the wire and through it are what created the current. Are we talking about the same thing?
    I recall thinking at the time "why didn't they, if they needed a certain amount of wire to attain a certain amount of output, make the wire into a collapsable sail or dish? Perhaps I heard it wrong or the reporter got it wrong....?
    Again let me thank you for your wise discorse on this matter!
Page 1 of 2 12
  1. Nikola Tesla Medal Engraved via CNC
    By dcarr in forum Community Club House
    Last Post: 02-23-2008, 07:46 PM
