586,051 active members*
3,865 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > PM25MV - Looking for quality Spindle Bearing Replacements
    Dec 2017
    I was doing some maintenance on my mill this weekend and the spindle started making bearing noise and I would like to replace the bearings with a higher quality product.
    Does anyone know of quality replacement bearings for the PM25MV?
    P/N if you got it.
    Re: PM25MV - Looking for quality Spindle Bearing Replacements
    I dont have a PM25 but rather a G0704. I've been through my fair of spindle bearings, but VXB.com has a wide variety and their shipping times are usually pretty minimal. I'm sure that whatever size bearings the machine uses are standard and easily found on VXB. Just try to find bearings that are rated for whatever RPM you can achieve. The spindle bearings on these machines are really only stressed when you start running high RPM spindles, IMO. Keeping coolant and dirt out of them can be a problem depending on your machines arrangement.
  1. PM25MV CNC Mach 3 Spindle control question
    By yz400fer69 in forum Benchtop Machines
    Last Post: 02-26-2019, 10:19 AM
  2. PM25MV faster than 2500 RPM spindle but with rigid tapping?
    By hackish in forum Benchtop Machines
    Last Post: 12-26-2018, 06:13 PM
  3. High quality linear bearing at low cost
    By Jakob in forum Linear and Rotary Motion
    Last Post: 05-04-2017, 02:38 AM
  4. vmc x axis thrust bearing replacements
    By mazakmazakmazak in forum Bridgeport / Hardinge Mills
    Last Post: 08-18-2015, 05:12 PM
  5. Craftex Mill/Drill Spindle Bearings Replacements
    By Jim Anderson in forum Benchtop Machines
    Last Post: 02-01-2015, 03:05 PM
