we have an AMADA AMS 3015 CL(T) system connected to a Amada FOM2 3015 NT C02 laser and recently we found that we cannot schedule job's to be cut.
The laser works fine and we can run the Automation it in Semi-Auto between the LST and FO systems,
however we cannot set it on full Automatic leave it on overnight to work through blanks when we are not here.
we can get the auto mode started but when we hit START on the C02 laser we get an error on the automation system that says "(0022) Invalid Data, Error Code".
we don’t even get an actual error code # with this error and I’ve checked that for this error within the manual it SHOULD also list an error code for error # 0022.
Most of them seem to relate to Macros and M Codes and whatnot but we can’t figure out what to do here.
we thought for a minute that it could be some issue with the transmission of the M33 code at the beginning, but we are not sure. Someone told us that It might be a setting somewhere, but we have the login for the machine to do the advanced stuff and we have looked thoroughly. We also do not know how to fix it if it was that being either of these issues.
Has anyone had this issue or know how I might be able to fix it?
I can provide more information if needed.
