586,042 active members*
3,668 visitors online*
Thread: THREADING
    THREADING
    i am a newbie to anything OKUMA
    okuma osp700L I keep getting a ( 1229 ALARM-A Spindle max revolution designation ) when trying to thread.
    here is my program
    thnaks for any help.
    $PXA7.MIN%
    N1 ( THREAD: OUTER THREAD1 )
    G40 G95
    G0 X60.
    Z20.0
    T040404
    G97 S200 M3
    G0 Z0.3054
    X0.415 M8
    G71 X0.1886 Z-0.709 I0 B60 D0060 U0060 H0598 F0.0394 M33 M73
    M9
    M05
    G0 X60.
    Z20.0
    M30
    May 2018
    7
    Re: THREADING
    I think you need a G50 max speed
    Feb 2011
    353
    Re: THREADING
    i would try putting decimal points in the d/u/h
    not sure if the control needs them but my manual for a osp5020l uses them-- your control maybe like a fanuc that can do it with out the decimal points
    the G97s200m3 should lock up the rpm's to 200 while threading
    try single block to see just where the machine alarm's out do you get by the g97 line and alarm out on the g71 line ?
    Jul 2010
    287
    Re: THREADING
    You do need the decimals on the D/U/H characters of code.
    You also need a G50 command.
    The alarm itself is because you don't have a G50.
    Make it read:
    N1
    G50 S500
    G40 G95
    You will be fine.
    If you don't put the decimal the thread cycle is going to act REALLY weird.
  1. Replies: 2
    Last Post: 04-11-2019, 05:40 PM
  2. Threading - always too big
    By dannirr in forum Tormach Slant Lathe
    Last Post: 10-17-2017, 02:51 AM
  3. THREADING: How to add threading parameters to the Init file?
    By jeffserv in forum Dynomotion/Kflop/Kanalog
    Last Post: 03-22-2015, 06:50 PM
  4. threading
    By MetalZilla in forum News Announcements
    Last Post: 01-26-2013, 01:32 AM
  5. Threading
    By rwskinner in forum Mini Lathe
    Last Post: 05-13-2010, 04:44 AM
