586,108 active members*
2,986 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Should steppers be wired with "twisted pairs"?
Results 1 to 6 of 6
    May 2007
    380
    When wiring stepper motors, should they be wired with twisted pairs? If so, what are the correct "pairs" on a 6 wire motor? I never seem to find any information on this, but when stepper shopping on ebay, I often see motors with the leads in twisted pairs.
    John
    Jul 2005
    450
    twisting wires as pairs is done for interference immunity. The theory is that if you have a differential signal sent along two twisted conductors, then they will both recieve the same noise, and as the signal is differential it cancels out.
    Stepper wires dont need to be twisted, as any noise will be irrelevant compared to the voltages on the wires.
    That said it is good practice to use shielded wire, and ground the shield at one end. The reason for doing this is that the stepper wires will radiate EM noise, which may be picked up by nearby electronics, and a grounded shield removes this problem. For small steppers this is less of an issue, and it probably wont hurt things if you dont, like i said its just a good practice.
    24221
    Wires that carry appreciable current produce E.M. field, this field can be cancelled to a great extent by twisting two conductors together that have opposite field (e.g. feed and return wire), by doing this, the fields tends to cancel each other out, therefore reducing the radiation and the effect on lower level signal wiring.
    Al.
    Albert E.
    Jul 2005
    450
    oops, didnt really think of using twisted wires to reduce emmission, Al is completely right on the emmission front, i just never had to worry about it as i use shielded wire.
    Nov 2006
    7
    Quote Originally Posted by johnmac View Post
    John
    You should use twisted triples with a 6-wire motor. One of the wires will have zero current making it in effect a twisted pair.
    Regards,
    Tim.
    May 2007
    380
    Thanks!
  1. "low end" HF Spindle or "high end" router for about $1000?
    By biomed_eng in forum DIY CNC Router Table Machines
    Last Post: 01-06-2012, 07:15 AM
  2. Has anyone looked at the "JET" or "Shop Fox" manual machines?
    By boosted in forum Uncategorised MetalWorking Machines
    Last Post: 03-05-2007, 04:33 AM
  3. Vertical system "jerks" and "bangs"??
    By REVCAM_Bob in forum Servo Motors / Drives
    Last Post: 06-12-2006, 03:09 PM
  4. How come steppers say only "~5v" on them, and people drive them with 48v+?
    By radicooldude in forum Stepper Motors / Drives
    Last Post: 02-18-2006, 01:35 AM
