Hi
Hello friends, I just joined the forum now.I designed a cnc router and chassis production is finished. I am currently installing the electronics. Router dimensions y 2800mm x1450 mm z450mm
Standard 3 axis cnc router In addition I have the 4th axis that can rotate 360 ??degrees.this axis will turn 90-180-270-360 degrees.consider a wood panel spindle holes in the surface and side hole in 4.axis .My axis motors nema 34 12nm stepper.I haven't bought a cnc control board or control panel yet.this is my first cnc router and my knowledge is very little.
I have no knowledge of software.i use autocad 3d max solidwoks very well but i don't have cam knowledge.
If you help me in this matter, you will make me very happy
Thanks in advance to everyone for help
