586,058 active members*
3,465 visitors online*
IndustryArena Forum > Community Club House > General Off Topic Discussions > tracking changes in z height of material.
    Nov 2016
    Question tracking changes in z height of material.
    I am engraving 2' x 2' plaques where the metal is close, but not exactly flat. And any change in depth results in less than stellar final products, because the text i am working with it pretty thin. I have a dual drum sander that get things closer to flat, but only closer. I am currently using a spring loaded tool, which does make things a little better, but my depths across multiple pieces are inconsistent. Sometimes it is a heavier cut, and when the pieces are lined up the depth changes become very apparent.
    I have a Laguna IQ Pro.
    Is there any machine, or add-on that can track the changes in z height so that my letters are consistent?
    Any other ideas?
    Nov 2012
    1267
    Re: tracking changes in z height of material.
    Check out Autoleveller, that's what I have been using for that purpose.
  1. Help wiring Tool Height/ Z axis height base into C10 BOB
    By SpecialEd in forum Tormach Personal CNC Mill
    Last Post: 11-21-2016, 02:13 AM
  2. HPR130. THC will not auto adjust to material height.
    By frostystones in forum Hypertherm Plasma
    Last Post: 07-30-2016, 06:35 AM
  3. Z tracking possible?
    By Epiphany in forum Dynomotion/Kflop/Kanalog
    Last Post: 08-06-2014, 11:08 PM
  4. Problem with cutting tool height to material
    By paulkr in forum SheetCam
    Last Post: 10-28-2008, 07:56 AM
