586,061 active members*
4,529 visitors online*
Results 1 to 14 of 14
    Jan 2012
    163
    wiring power to a driver?
    I've begun to wire my steppers I'm stuck , To connect power my driver it has AC1 & AC2 is one POS. and one NEG.?
    Attachment 436600
    Re: wiring power to a driver?
    AC power does not use positive and negative.
    Jan 2012
    163
    I have 60volt switching power supply has POS and NEG. outputs
    Jul 2018
    6339
    RM - but a SMPS puts out DC you need an AC output. You need a 20-80V AC power source. Put up an image of the output of the SMPS....Peter
    Yes, you have a DC power supply, and a drive that requires AC power.
    Nov 2012
    1267
    A DC power supply (30 to 110VDC) will work too, according to the manual. As long as it has enough power.
    Jan 2012
    163
    here is my power supply Attachment 436606
    Jan 2012
    163
    citizen dream you say it don't matter ac or dc ? does it matter which way i hook it up?
    Jul 2018
    6339
    COD - Can you show image of where in manual it says DC is OK? Why do they say AC when they could have said AC/DC??? Found it but does seem odd.... Peter
    it mentions it in 3 places but does not say which polarity to use so maybe does not matter???
    Nov 2012
    1267
    Polarity does not matter. Input power goes to a diode bridge inside the servo, so you can connect "+" and "-" whichever way you like.
    Jan 2012
    163
    CitizenOfDreams Thanks! i will give it a go
    Jan 2018
    1516
    I'd buy a toroidal AC supply. Something like a dual output 40v unit and wire it in series to output 80v AC.
    A 60v DC might be a dissapointment.
    Such as:
    https://uk.farnell.com/multicomp/vtx...40v/dp/1675097
    Or for a powerful system:
    https://uk.farnell.com/multicomp/vtx...40v/dp/1675107
    https://electro-dan.co.uk/electronics/wiringtrans.aspx
    Feb 2008
    521
    As no one else has mentioned it - that is a SERVO driver and you have said you are using STEPPERS with encoders elsewhere ? ? ? Servos maybe AC powered - steppers are most certainly DC powered and polarity connections will be important yo ensure rotation direction is as commanded and not reversed!
    Nov 2012
    1267
    Quote Originally Posted by kawazuki View Post
    We are talking about the power supply connection, not the motor connection. AC/DC power has nothing to do with the motor type, it depends on whether the driver has a built-in rectifier. This particular one does, so it can be powered with either AC or DC.
  1. need help, driver to BoB wiring
    By CAD226B in forum Shopmaster/Shoptask
    Last Post: 09-08-2016, 07:52 PM
  2. Wiring a RTA NDC 06.V stepper driver
    By swede0 in forum Stepper Motors / Drives
    Last Post: 03-26-2016, 05:28 PM
  3. Motor driver wiring
    By unbridled in forum CamSoft Products
    Last Post: 07-24-2013, 07:24 PM
  4. Step Motor Driver and Power Supply Wiring
    By mcan in forum Open Source Controller Boards
    Last Post: 01-19-2007, 11:22 AM
  5. OMS driver wiring help.
    By cnc2k in forum CNC Machine Related Electronics
    Last Post: 12-26-2004, 01:11 AM
