586,060 active members*
4,572 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Call Updated Sub Program
    May 2018
    74
    Cool Call Updated Sub Program
    Hello All,
    I wondering how can we update the data or memory of the control (OKUMA 700). Let say my main program is:
    Comments...
    N1....
    N2 CALL O0001
    M01
    N10 CALL O0001
    And my sub is: (.SSB)
    O0001
    G01 X=1.25 Z=12.
    RTS
    At the block N2 the main program call sub 0001 and execute it then M01 will stop the machine. So the question is if I update the sub 0001 with new X and Y (I can do that in my PC) and reload the sub without reload the main (PROGRAM SELECT) and continue the main program to N10. But the X and Y value still not change. And if I reload the main (PROGRAM SELECT) then the sub will be updated to new value.
    Is there any way to delete the memory to clear out X and Y value without reloading the main program so that I can continue to run block N10 with the new value?
    Jun 2015
    4154
    Cool Re: Call Updated Sub Program
    hy nodo, if you wish, please be a little more specific, and explain what you wish to achieve ... you have explained the method, but you did not explained the goal, and i am afraid that the method that you wish to apply is not the best for your goal, simply because the method does not seems to be common
    ... you have used a linear type of code, and changed it by editing & reloading the file + praying&hoping to work
    ... you should use a parametric type of code, changing the way it behaves by using arguments inside your main program, so to avoid the need to edit & reload the file / kindly
    Code:
    [ main program ]
        CALL ONODO V1 = 1.25 V2 = 12 V3 = 10/10
        M = V3
        CALL ONODO V1 = 12.5 V2 = 21 V3 = 0001
        M = V3
    M = 01 + 1
    [ soubroutine ]
        - you may keep the soubroutine also inside the *.min file
        - is not critical to use a different file, like *.ssb eq
    ONODO(CHAU)
        G = V3 X + V1 Z + V2
    RTS
    Apr 2009
    1262
    SSB is system sub and loads at power up. SUB is user sub and loads upon CALL statement.
    You must choose wisely...
    Experience is what you get just after you needed it.
    Jun 2015
    4154
    hy mr wizard, i was teached to use ssb, and i can tell that on osp300, they update only during program select
    even more, if i delete the program after it was selected, it will still run, but it will fail if i will try to re-select it
    i believe that having a soubroutine updated only during the call statement, is a trick to manage available memory, thus somehow similar to using pselect, allowing to load into the buffer only a slice of the cake i believe that having a soubroutine loaded only during the call statament leads to downtime, and for this reason i believe that it was an advantage for machines with limited memory, but i see no reason to use it on osp300
    however, you made me curios, and i will look futher more into ssb*s and sub*s / kindly
    Apr 2009
    1262
    The OSP 300 is running on Windows but the OSP 700 is not so the way they handle SSB files is different. Program select vs power up.
    Best regards,
  1. Replies: 1
    Last Post: 09-09-2019, 10:25 PM
  2. sub-program call is supported by postprocessor
    By cutleader in forum CutLeader
    Last Post: 04-10-2019, 01:36 AM
  3. 4-axis hmc (op10-op20 program call)
    By indiex in forum Fanuc
    Last Post: 05-08-2013, 05:21 AM
  4. Fanuc 11m call sub program
    By rick kroeze in forum Fanuc
    Last Post: 04-21-2012, 04:59 PM
  5. command for main program call
    By Flyingmatt in forum Index and Traub
    Last Post: 09-16-2011, 02:20 PM
