586,076 active members*
4,012 visitors online*
    Jul 2007
    59
    Kent KTM 380 vertical mill
    Hi
    I just purchased a Kent KTM 380 vertical mill after a long search on
    ebay (particularly for something near me).
    I have not come up with much information on this mill online (no
    scanned copies of user manuals and service information).
    From what I gather, the spindle is the step pulley type, so a little
    more time consuming to change speeds, but at the same time relatively
    simple compared to the variable speed units.
    Its a 9x42 unit, thus relatively large for a home shop, but I doubt I
    will regret the extra size or weight after getting it moved in.
    Are there any potential issues to watch for on this machine, besides
    the normal wear and tear that one expects on something 26 years old ?
    Where was the machine built and can one expect good quality castings
    etc, compared to current Taiwanese & Chinese mills ?
    Keith
    Jul 2007
    59
    Wow. I was hoping someone out there would know this unit. It seems like Kent has been around for a long time, but maybe they imported and resold the knee mils ?
    I did write to Kent via the "contact" page of the Kent USA website but I have had no response there either.....
    Hopefully this is not an "orphan" machine...
    Keith
    Aug 2007
    Re: Kent KTM-380
    I am auctioning one of these mills next week. I do not have manuals or diagrams on this model.
    Specs: 2HP 8-speed step head: 65, 115, 200, 285, 615, 1100, 1910, 2700 rpm. The spindle is R8 with 5" quill travel. Head tilts up and down 45 degrees, left to right 90 degrees. Ram travel is 23".
    This machine is a Taiwanese Clausing-copy. It is a lot more rigid than the Bridgeport-copies. It was built back when Meehanite casting was standard for Taiwan imports. A very capable canidate for cnc retrofit.
    These mills are 30 years old and will outlive any newer import like Jet, Birmingham, etc. Good machine!
  1. D&M 4 cnc vertical mill documentation
    By cthomas in forum Vertical Mill, Lathe Project Log
    Last Post: 07-03-2018, 01:59 PM
  2. Grizzly Vertical Mill?
    By orionstarman in forum Knee Vertical Mills
    Last Post: 05-28-2008, 03:06 PM
  3. Greetings All! Help! Fanuc-Kent Mill
    By adodado in forum Fanuc
    Last Post: 09-08-2006, 04:50 AM
  4. Best Vertical Mill?
    By bvandenb in forum Haas Mills
    Last Post: 04-20-2005, 11:47 AM
  5. Cheap vertical mill
    By cncadmin in forum Uncategorised MetalWorking Machines
    Last Post: 01-21-2004, 11:50 PM
