586,062 active members*
4,532 visitors online*
    Jan 2012
    163
    I'm stuck again, wiring
    My driver has Pul+,Pul-,Dir+,Dir-,Ena+,Ena-, i'm using C11G board, my concern is the wiring diagram doesn't use Ena+,Ena- there diagram uses c10 board for example. If It make any difference I'm running closed loop steppers https://www.cnc4pc.com/pub/media/pro...es/WS_89_1.pdf
    Nov 2009
    4415
    Re: I'm stuck again, wiring
    From everything I read the enable pins dont have to be used. If you do use them, there is an extra layer of protection. How to wire the enable pin on a stepper drive?
    A lazy man does it twice.
  1. 8 wiring encoder wiring to step2linear
    By taoufikbenzart in forum Viper Servo drives
    Last Post: 11-24-2019, 08:41 PM
  2. Replies: 19
    Last Post: 07-30-2015, 01:44 AM
  3. wiring check please. parallel wiring to maximum current to servo motors
    By Novett in forum CNC Machine Related Electronics
    Last Post: 10-11-2014, 07:54 PM
  4. Another sPID, G540, and Mach wiring question for the wiring challenged..
    By adam_m in forum DIY CNC Router Table Machines
    Last Post: 01-02-2014, 01:29 AM
  5. X value stuck at 0.001
    By OCNC in forum NCPlot G-Code editor / backplotter
    Last Post: 02-16-2011, 12:42 AM
