586,471 active members*
3,408 visitors online*
Results 1 to 3 of 3
    Jun 2006
    12
    My Axis is lagging
    I am using Mach 3, and when coming up out of a pocket with the Z axis, it seems that the next block begins to execute before the z motion is finshed.
    Is this an indication of too high of feed rate?.
    I am using steppers.
    I wind up with a curved interface, instead of a 90 degree corner
    35538
    You're in Constant Velocity mode, G64. You can set Mach to Exact Stop mode (G61) in the general config screen, and you'll get sharp corners. The down side to exact stop mode is that mach3 will come to a complete stop at the end of every move. Higher acceleration settings can minimize the corner rounding in CV mode.
    Jun 2006
    12
    thanks, I am only cutting wood, I can live with the lost time.
  1. A 5-axis CNC machine including a rotary axis
    By synthetiklone in forum CNC Wood Router Project Log
    Last Post: 07-12-2013, 09:32 AM
  2. the Difference of 2-Axis and 3-Axis of Vertical Mill Machine
    By begacon in forum Knee Vertical Mills
    Last Post: 07-30-2009, 12:31 PM
  3. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
  4. 4 axis controller for 3 axis machine?
    By tybrenis in forum Community Club House
    Last Post: 01-20-2007, 04:12 AM
  5. Options for 2 Axis Head (to make 5 axis)
    By drewgarth in forum DIY CNC Router Table Machines
    Last Post: 07-12-2006, 06:37 AM
