586,114 active members*
3,348 visitors online*
Thread: A axis
    Sep 2019
    54
    A axis
    Hi all
    I think I have a problem with my breakout board
    It's a HG08 from cnc4you
    X and Z axis working fine
    But Y axis moves only one direction when using keyboard or when I hit tab and click on arrow direction using mouse,
    I have checked all wiring,
    Have checked all pins on serial cable,
    Have swapped out serial cable for new one, but no difference,
    But the HG08 board has a A axis output,
    So I plugged my Y driver into the A axis on breakout board,
    In pin and ports, motor outputs
    I changed my Y axis step pin and dir pin to the
    A axis,
    Resigned my A axis hotkeys to where my Y axis hotkeys was
    And it works fine now jogging it around the table,
    But when I run a program Mach still thinks
    the original Y axis is controlling the Y movement
    But it's not,
    So is there any way I can change Machs Y axis to run the A axis permanently,
    Badly stuck I could buy a new breakout board
    Apr 2004
    5737
    Re: A axis
    When you changed the pin assignments of the Y axis to those of the A axis, did you also change the A axis pins to those of the former Y axis? If not, it may be confused as to which is what. Usually, axes that run in only one direction have a wire loose somewhere; you might try remaking all the connections to your Y axis motors and logic pins.
    Andrew Werby
    Website
    Sep 2019
    54
    Yep I have done that with the A pins
    When I swap X and Y outputs from the breakout board to the drivers, the problem ends up on the X axis, so I don't think there is any issue on that side,
    Which makes me think it's a problem around the breakout board
    Regards
    Quote Originally Posted by awerby View Post
    Sep 2019
    54
    I wonder can I change the pins coming out of the pc,
    Just so I could rule out any problem with the parallel port,
    As I am not using any of the other pins on the port
    ie, limits
    Quote Originally Posted by Dem1 View Post
    Regards
    Sep 2019
    54
    Hi
    Just found a solution,
    Just had to slave the A axis to the Y axis, so that should be all good now
    ie, limits
  1. Replies: 1
    Last Post: 01-28-2024, 06:26 PM
  2. Replies: 16
    Last Post: 09-11-2017, 10:31 PM
  3. Replies: 0
    Last Post: 04-27-2016, 04:08 PM
  4. Replies: 1
    Last Post: 11-17-2015, 07:37 PM
  5. Replies: 0
    Last Post: 08-04-2013, 05:30 AM
