I would like to use a joypad that looks like the PS3.
Can we use a current joypad because I can't assign the commands in the software configuration.
You could use it as external USB device. Take a look TNGv2 API examples for Arduino.
Unfortunately I have no other way to know how API works... :-((((
How can I adjust the mouse wheel to move along the axes?
I don't understand this question.
For example, I press a button on the keyboard + turn the wheel on the mouse and the axis moves. Can I do this? Mouse wheel acts as an encoder
I don't think there is a way to directly assign axes to Commands as there is in computer games--but it is an industrial controller, so not to be expected. Planet cnc have provided lots of tools to do this in the api and arduino code, or you can use a freeware program like joy2key or https://simhq.com/forum/ubbthreads.php/topics/3899105/mmjoy-mmjoy2-build-your-own-usb-controller to interface your controller or mouse.
How to make the screen refresh more often ??? I change the "refresh rate", only numbers are accelerated, and the main screen doesn’t change. Why even make such slow-down default settings?
found half a day later. as if specially transferred to another place so that they would suffer.
