586,106 active members*
3,159 visitors online*
Page 1 of 3 123
Results 1 to 20 of 54
    Aug 2007
    224
    Diplomatic turret BSV-N-120
    dear members
    Facing trouble about Diplomatic turret BSV-N-120 locking ..turret going its position but not locking. ..every things good before machine relocate ..please need help
    regards
    asif
    May 2016
    526
    Re: Diplomatic turret BSV-N-120
    Is the turret indexing in the correct direction e.g. going 1,2,3,4?
    Aug 2007
    224
    yes brother ...turret operate with jog mode also with mdi thru tool change command..please check the operation sequence on attach jpeg till highlighted the area turret work well after that stuck not complete the cycle my understanding that the at this point turret motor need to be start reverse direction to lock the dist but not happening..
    May 2016
    526
    Yes you've said that it works in jog and mdi I asked does the turret go in the correct direction ?
    You said it was working one place and moved so have you checked phasing
    Aug 2007
    224
    yes turret goes in correct direction ..i already change phase to check direction...
    May 2016
    526
    Check diagnostics that locking sensor has released , then check relays that it's telling unit to activate locking pin . Check diagnostics that encoder is changing
    What machine is unit on
    Aug 2007
    224
    ok which diagnostics number...??? machine is colchester2000l cnclathe
    May 2016
    526
    1st or 2nd page I think you can press locking solenoid to confirm
    Aug 2007
    224
    there are two proximate switches one for indexing control and other for locking control ...you are saying i have to check these sensor on diagnostic parameters either that they change the bit number or not when we activate ..
    May 2016
    526
    Yes , plus check the encoder changes diagnostics as it moves. Check 24v supply also
    Aug 2007
    224
    dear sir yesterday i have checked all sensor and encoders and they work well..diagnostics 16 response well on every tool change..diagnostics 17 bit 1 change when encoder metal ring come under the sensor but one thing not happening ..every time when tool change command activate the diagnostics 17 bit 1 change 0 to 1 within second to complete the cycle..but this is not happening on my machine.after tool change command activate diagnostics 17 bit 1 change 0 to 1 but not back to one because encoder metal ring is not back to it actual position..what happening sir need your help..also do you know sir less Robin he is ex electrical engineer cholesterol machine tool company ..4 years ago he helped me alot to resolve my problem..
    regards
    asif
    May 2016
    526
    Yes I know les
    Does the plunger engage you can tell by taking the cap off , this activates 16 bit 7 and tells the turret to reverse and clamp so activating 17 bit 1
    Aug 2007
    224
    ohh good to hear about les Robbin.. how he is ....please say salam from me when ever you meet him
    yes plunger engage and diagnostics 16 bit 7 change when tool change command activate also with jog mood..
    i dont understand this line(and tells the turret to reverse and clamp so activating 17 bit 1)what do you want to say???
    please response
    May 2016
    526
    When turret gets to it's position the plunger engages and activates the 16 bit 7 this then tells motor to reverse and lock which then turns on 17 bit 1
    Aug 2007
    224
    Quote Originally Posted by mbservice View Post
    ok yes ...the turret gets to it's position and plunger engages and activates the 16 bit 7 till now every thing is ok but some how they do not tells motor to reverse and lock which then turns on 17 bit 1...i think the diagnostics 16 bit7 avtivate but do not sending the signal for the next moment to complete the sequence.and this is what we need to find....
    May 2016
    526
    Possibly relay fault
    Aug 2007
    224
    ok brother ..but how to i find the relay which is faulty???..i have a machine manual there are also a diagram or relay connection but i cant interpret due to lack of electronic knowledge...can you guide me?
    Aug 2007
    224
    I have checked relay and no issue...now what..some one advise me that check macro program 9000 series.. maybe macro program can be distrub...need your advice
    May 2016
    526
    If your turret is continually spinning I'd say your solenoid has failed.
    Your machine does not use a 9000 program to control the turret
    Aug 2007
    224
    no..... sir........ turret is not continually spinning.turret follow tool number accurately ..also work in jog mode..the issue is turret not locking ..in other words motor not reverse activating to complete the tool change cycle..
    turret not to reverse and not clamp so not activating diagnostics 17 bit 1..
    regards
    fsa
Page 1 of 3 123
  1. Replies: 26
    Last Post: 03-02-2023, 11:25 AM
  2. Turret lost after changing turret driver battery
    By Michael82 in forum Daewoo/Doosan
    Last Post: 12-12-2019, 01:00 PM
  3. Aligning turret on a Daewoo Puma 10, 12 tool turret
    By AirChunk in forum Daewoo/Doosan
    Last Post: 06-03-2016, 02:37 AM
  4. alarm turret 1000 turret conuter error
    By aaagt78 in forum Fanuc
    Last Post: 04-08-2015, 04:14 PM
  5. colchester combi 2000 diplomatic turret.
    By Toolmaker666 in forum Uncategorised MetalWorking Machines
    Last Post: 10-06-2009, 03:43 PM
