586,103 active members*
3,466 visitors online*
    Dec 2015
    filler pump moror problem
    we have a sodick A280l wire edm. the main bearing on the filler pump motor seized while the machine was cutting a part. we rebuilt and replaced the motor but it does not start. Is there a reset or fuse or overload somewhere in the control panel?
    Jun 2022
    Re: filler pump moror problem
    Did you figure this problem out? I am having the same issue.
  1. Pump problem
    By Shensai in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-20-2012, 02:18 AM
  2. Two questions, bits and filler
    By Buzz239 in forum Engraving Machines
    Last Post: 11-06-2012, 12:53 PM
  3. Oil Pump problem?
    By JohnJW in forum Haas Mills
    Last Post: 07-06-2011, 03:03 PM
  4. Oil pump problem
    By john84hall in forum Bridgeport / Hardinge Mills
    Last Post: 05-19-2011, 03:59 AM
  5. Filler Rod for 4130?
    By Chris64 in forum Welding Brazing Soldering Sealing
    Last Post: 09-30-2007, 06:01 AM
