587,006 active members*
2,894 visitors online*
IndustryArena Forum > CAM Software > MadCAM > MADCAM broken with latest version
Results 1 to 9 of 9
    Apr 2018
    14
    With the latest version of MADCAM I can no longer postprocess toolpaths.. I receive the error message: Access Violation error raised with message (than a bunch of numbers). I have never received this error message before. Can I revert to a previous working version?
    // JRS_CNC
    Mar 2004
    1661
    Re: MADCAM broken with latest version
    yes you can, if you have the installation file.
    Before you try that, try to reinstall the latest release.
    Apr 2018
    14
    Thanks for the information. Turns out I changed the screen settings in WIN10 from picture/transparent to solid color/not transparent. With the latter setting I had the MADCAM problem I described. Changing back to the default settings MADCAM works fine, so false alarm, I guess. Strange the screen settings changed MADCAMs behavior but sometimes computers are strange.
    JRS_CNC
    Mar 2013
    10
    Quote Originally Posted by JRS_CNC View Post
    JRS_CNC
    I'm also having this issue. Windows 10, Rhino 6. How did you fix this?
    Mar 2013
    10
    I worked this out. For me madcam was pointing to older machine definitions from earlier versions of madcam in %User%\Documents\MadCAM.....
    I repointed it to %User%\AppData\Roaming\5XCNC\.... and the access violation is now gone.
    Curt
    Mar 2013
    10
    After more working this is still cropping up and causing some pain.
    The error:
    EAccessViolation error raised, with message : Access violation at address 0000000000000041379B in module 'madCAM6.dll'. Read of address FFFFFFFFFFFFFFF.
    The read of address FFFFFFFFFFFFFFF is the problem. Somewhere madcam is getting a bad address. I suspect an uninitialized variable issue.
    I have tracked it down the the postprocessor file.When it happens, if I switch to another postprocessorit works. Then if I switch back it doesn't work. If I do that a few times then the original postprocessor works. It doesn't seem to depend upon which postprocessor it is.
    I suspect an uninitialized variable somewhere, which after switching back and forth eventually gets initialized.
    Feb 2018
    7
    Quote Originally Posted by curtdutt View Post
    The error:
    I can reproduce this EAccessViolation :
    error will come with post here
    under:
    N"lnbr" (Nc generated on : "datetime")
    N"lnbr" (Documentname "documentname")
    N"lnbr" "documentname"
    N"lnbr" (Tool Path Profile "method")
    N"lnbr" Tool Number = "toolnr")
    N"lnbr" (Tool Offset Number = "tooloffsetnbr")
    in the third line there is written "document name" and not (document name)
    when I place the () around the text the error is disappeared.
    maybe there is a line likes this in your post?
    Feb 2006
    183
    This problem has been solved with SR 14, February 25.
    Joakim
    Mar 2013
    10
    I just verified it that this release solved my problem
    Thanks Joakim!
    -Curt
  1. Replies: 18
    Last Post: 08-03-2017, 11:53 AM
  2. Latest madCAM making 4 Axis Drive Surface
    By Mauri R in forum MadCAM
    Last Post: 05-21-2017, 04:29 AM
  3. Will latest Madcam work with Rhino 4.0
    By brian257 in forum MadCAM
    Last Post: 03-31-2015, 09:37 PM
  4. Replies: 5
    Last Post: 03-27-2014, 08:13 PM
  5. madcam locked up after latest release DL
    By williamsmotower in forum MadCAM
    Last Post: 12-04-2011, 12:45 PM
