586,061 active members*
4,436 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > has anyone used a cylinder slide for guide rails?
    Question has anyone used a cylinder slide for guide rails?
    i found a business out my way that deals in reselling liquidated industrial goods. one of the things i keep finding are these pneumatic slide cylinders, and i cant help but wonder if they are even worth looking at as far as cnc gantry is concerned. it also helps that every time i find one they are almost always dirt cheap. now im not looking to keep the air part working, i just want the slide of it. i'm figuring if i just remove the end caps and away she goes. i posted a picture of the one i'm thinking about so you guys know what i'm talking about
    am i completely way off base here, or is this a tree worth barking up? my current machine is a genmitsu 3018 so any amount of rigidity is more than i have now and probably more accurate.
    15362
    Re: has anyone used a cylinder slide for guide rails?
    Quote Originally Posted by Snowfox222 View Post
    They are used on a lot of commercial Router for different stations for Drilling Etc some are used for multi spindle machines also, they don't normally have much travel, so not that useful
    Mactec54
  1. cylinder wood plat guide for Routeur.
    By QUOY in forum Uncategorised WoodWorking Machines
    Last Post: 10-28-2019, 01:13 PM
  2. DIY Guide rails?
    By country kid in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 08-10-2015, 08:49 AM
  3. SBR20 Linear slide rails - Grease or Oil?
    By Semus in forum Linear and Rotary Motion
    Last Post: 02-11-2015, 02:52 AM
  4. THK FBW/FBW2560R Linear Bearing Guide Slide Rail
    By BackyardWorkshop in forum DIY CNC Router Table Machines
    Last Post: 09-02-2010, 07:52 AM
  5. Guide Rails
    By STEVE P in forum Material Machining Solutions
    Last Post: 11-22-2005, 11:48 PM
