586,108 active members*
3,023 visitors online*
IndustryArena Forum > CAD Software > Logic Trace CNC/DXF > Opinions on the Logic trace board
Results 1 to 7 of 7
    Dec 2012
    I have a 4x4 plasma table mainly just cutting signs and small parts. I want to expand and was considering a Logic trace board. I do not have a CAD background and usually have my brother draw things up when I need them, but that is hard to get done sometimes.
    I would like to know if it is worth the money and is there work out there to justify my purchase?. Since I don't have one I don't know what opportunities are out there with this setup.Any advise will help. Thanks. Bob
    Aug 2009
    1573
    Re: Opinions on the Logic trace board
    Hi Bob,
    Try this https://www.freecadweb.org/
    Welcome to the zone,
    DJ
    Aug 2013
    If you are making complex shapes, it may be worth it. If it is something that you can easily draw up using geometric shapes, you probably don't need it. And even after you digitize something, you still have to tweak it and fiddle around with it to get it just right. A big part of my business is cutting foam with my router for gun cases, and I use mine every day.
    Oct 2007
    1025
    that's exactly why I bought John Walsh's drawing board back in 2008, I did not like cad drawing and with all the other woodworking functions I had to do I could not get good enough
    working with cad, this system you use his board and software and a pen and you draw.
    The only decision is the size of board you require.
    Aug 2013
    I have a 48x36 board. When I get an item longer than 4', I just digitize it in 2 pieces, and stitch them together in Aspire. The point being that you may not need one as big as you think.
    Oct 2007
    1025
    so one board would do, contact John Walsh ask him!
    Also your best source of diagrams....coloring books
    Nov 2013
    152
    I have a Logic Trace board. When you need it, it’s worth the cost!
  1. logic trace curve fir through points
    By woodman08 in forum Logic Trace CNC/DXF
    Last Post: 11-08-2018, 03:32 AM
  2. Buying logic trace
    By Rammer in forum Logic Trace CNC/DXF
    Last Post: 02-05-2015, 02:46 PM
  3. Replies: 0
    Last Post: 12-04-2014, 02:38 AM
  4. logic CNC trace please help !
    By UK SITE WELDER in forum Logic Trace CNC/DXF
    Last Post: 11-12-2014, 02:01 AM
  5. logic trace software and drawing boards
    Last Post: 03-20-2014, 02:19 AM
