586,042 active members*
3,701 visitors online*
    Nov 2019
    41
    Removing play in Z axis
    What is the intended way to adjust the bearing side-to-side for the Z axis? I have a a lot of play https://sendvid.com/6cq50f94
    I tried loosing the bolts holding the bearings on to see if there way movement in their holes and I could just move them over and tighten them, but there was none. My only guess at this point is to shim out the vertical metal rails that the bearings ride in.
    I am hoping a Joe's builder can provided some insight. I am a 3rd owner of this fairly well built Joe's machine.
    Re: Removing play in Z axis
    The bearings on one side should be on eccentric bushings that you turn to tighten.
    The angle iron isn't helping. Switching to precision rail would help, but you'll always have some play with that system.
    Nov 2019
    41
    Yes there were eccentric bearings on the one side. Thank you.
    Adjustment of these help resolved play as well as binding that was taking place when the Z axis moved up.
  1. Removing the Gantry v. Removing Z Axis
    By GME in forum FineLine Automation
    Last Post: 10-09-2018, 09:33 PM
  2. Z axis play
    By bmurph in forum Benchtop Machines
    Last Post: 01-24-2012, 07:17 PM
  3. Play on X axis
    By Peat in forum Cincinnati CNC
    Last Post: 10-28-2011, 11:45 AM
  4. Is there a way to take play out of Z axis?
    By aadrew10 in forum Haas Mills
    Last Post: 06-10-2011, 07:16 PM
  5. Z axis Leadscrew play
    By Smackre in forum Linear and Rotary Motion
    Last Post: 05-08-2006, 04:37 AM
