586,426 active members*
3,664 visitors online*
    May 2005
    94
    sl-10 coolant nozzles
    What do folks use to get coolant to the tip of drills in a Haas turret? the little brass gimbal gizmos that the machine comes with don't extend nearly enought to clear a collet holder.
    We are sweating some copper tubing into the brass gimbals right now, should work ok.
    Apr 2004
    45
    coolant
    your idea will work you can also use the block off plate and push coolant thru the collet or use drills with a thru hole
    Jul 2005
    12177
    I find with the high volume coolant pump there is so much coolant spraying around you don't need to aim it...everything gets hit .
    But we do more or less the same, extend the stock nozzles. What I have found convenient is brake line tube. It is cheap, can be bent into tight curves and you can get adapters to 1/8" pipe thread. We made some 1/8NPT tapped adapters with the little ball on the end.
    Oct 2003
    530
    I use the block off plate and the coolant flows through the collet holder. Sprays perfectly on the drill. It's easy to change over back to the nozzels, so might as well use the right tool for the job.
  1. Best coolant
    By machinist39 in forum MetalWork Discussion
    Last Post: 06-04-2019, 09:08 PM
  2. Looking for a better coolant?
    By shawn in forum MetalWork Discussion
    Last Post: 06-29-2009, 04:13 PM
  3. Coolant...Which and why?
    By ajl6549 in forum MetalWork Discussion
    Last Post: 12-08-2008, 03:02 PM
  4. Coolant or No Coolant when turning....
    By Crashmaster in forum MetalWork Discussion
    Last Post: 05-20-2007, 07:20 AM
  5. COOLANT (what are you using?)
    By carbidecraters in forum MetalWork Discussion
    Last Post: 01-22-2006, 07:31 AM
