586,116 active members*
3,458 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > "copy/paste" from one Arduino Uno to another
    Jun 2010
    1414
    I have a functioning Arduino uno board and the corresponding motor control stacked on top of it. I would like to have a spare board. How do I copy the settings of one set of boards, onto the other?
    I am using it to drive a nema 17 motor.
    Mar 2015
    410
    Re: "copy/paste" from one Arduino Uno to another
    You can read the settings by sending a $$ command to the controller. If you capture the output in a text file, you can then send this text file to the new controller the same way you do when sending a gCode file.
    You can use the Arduino terminal window to do this. Most gCode senders can also do this by logging the output. Some even have a utility to backup and restore settings.
    May 2005
    1662
    If it's grbl settings you need hfjbuis has provided the answer.
    If it's some non-grbl sketch hopefully a copy was stored somewhere. Otherwise...... trouble.
    Anyone who says "It only goes together one way" has no imagination.
  1. Multi-head or multiple extruder simotanious "follow me" copy print "mirror mode"
    By routermaker in forum 3D Printer / 3D Scanner Discussion
    Last Post: 10-26-2019, 02:34 AM
  2. Replies: 3
    Last Post: 10-07-2013, 01:43 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. Hiring Ad Paste "Rashid9"
    By rashid9 in forum Employment Opportunity
    Last Post: 11-29-2007, 06:11 PM
