586,721 active members*
3,062 visitors online*
Thread: Spindle FAN
Results 1 to 6 of 6
    Nov 2017
    23
    Spindle FAN
    Hello,
    I'm old spindle fan took a big chip inside and now is broken.
    In romania is pretty hard to find anything with 115v.... someone can help me with this info:
    From where to take a connection 220v AC without interfere with anything else, just for the spindle fan.
    Best regards,
    Oct 2008
    1637
    Re: Spindle FAN
    What voltage do you have your machine set up for? If it's set up for 220 volt 3 phase, then just take the fan leads to L1 & L2 for 220. Should be able to get it from the same taps your spindle inverter inputs are on.
    Actually, it shouldn't matter what voltage you have going to your machine. L1 & L2 going to your VFD for the spindle should still be 220.
    Richard
    Quote Originally Posted by Cosmin90 View Post
    Hello,
    Best regards,
    Nov 2017
    23
    Do you know where the fan is connected in the cabinet?
    Quote Originally Posted by rwskinner View Post
    Richard
    Oct 2008
    1637
    Re: Spindle FAN
    Looks like #29 #30 on Terminal Board 1, which should be all 120 vac. See Lower Side.
    I mentioned you could get it after the contactors at 2 legs L1 & L2 at the VFD drive or the power supply to the Servo Drives.
    Oct 2008
    1637
    Re: Spindle FAN
    Did this information help you with what you needed?
    Nov 2017
    23
    Re: Spindle FAN
    After one here ... your information is still helpful:d thanks and sorry I didn't answer fast.. but somehow I found a 110v fan. Now I want to make it shut down after 2 minutes machine non running.
  1. Replies: 3
    Last Post: 10-19-2018, 05:12 PM
  2. Replies: 6
    Last Post: 03-20-2017, 09:30 PM
  3. Replies: 39
    Last Post: 01-09-2017, 06:26 AM
  4. Replies: 5
    Last Post: 07-19-2013, 05:16 AM
  5. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
