586,882 active members*
4,007 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Hi All I am new to cnc.
    Feb 2020
    6
    Hi All
    I am kees, coming from holland, I was here before but can not log in anymore, so made a new membership.
    I do electronics so I did build a cnc for that, it is not yet ready so I need to have some info about the lineair rails from thk.
    I have for the task of pcb milling a little to heavy slider rails and even bigger slider blocks. These can fit a mill who can do steel so heavy the are.
    I want to ask if I can use just two silder blocks for this heavy rails, she are quite big and strong, when I use just two I have more plot area.
    dimensions of these are 58 x 70 mm, for me I think two rails and two carriers are enough.
    I like advice,and it is only for pcb milling, machine is made from high densitiy waterresistant woodfibre/mdf, really stif made, this is only because i want to see what it does and if i like it, then I can go maybe to aluminium system.
    Electronics like the drivers and processor boards I make myselfs.
    regards.
    Feb 2013
    48
    Re: Hi All I am new to cnc.
    Hi Kees60,
    See this post
    https://www.cnczone.com/forums/pcb-m...44316-cnc.html
    and scroll to post #15.
