586,036 active members*
3,620 visitors online*
    Feb 2020
    Invert axis vector machine
    I'm a beginner in the writing of post processor (… and in English too).
    I have this G-code: G01 X100 Y-200 Z-10
    with solidcam coordinate system (see attached picture 1)
    I want this code: G01 X100 Y200 Z10
    to match with my cnc machine.
    I try to rotate the x axe machine with id machine editor (see attached picture 2)
    But the G-code generate don’t change, I don't think that's the way to do it.
    Can someone help me figure out the right way to do this?
    May 2013
    37
    Re: Invert axis vector machine
    You can adding 3 new variables to gpp file and set the values like that:
    global integer dirX dirY dirZ
    dirX = 1
    dirY = -1
    dirZ = -1
    after that u can use find/replace feature with "match whole word" option and replace all:
    xpos
    by
    (xpos * dirX)
    ypos
    by
    (ypos * dirY)
    zpos
    by
    (zpos * dirZ)
    I'm guessing that your mach3 have wrong configuration. And you should by checking that first. I'm don't know how it working with drilling cycles. So please be careful!!
    Attachment 437506 Click image for larger version.
Name:	2020-02-29 23_25_44-.jpg
    Feb 2020
    Thank you very much for your reply.
    Can someone tell me what the machine parameter orientation vector option is for (in id machine editor)?
    Just one more thing, i don't have a mach3 but a Masterwood project 415.
    Quote Originally Posted by partur View Post
    dirX = 1
    dirY = -1
    dirZ = -1
    xpos
    by
    (xpos * dirX)
    ypos
    by
    (ypos * dirY)
    zpos
    by
    (zpos * dirZ)
    hi sir
    how are you
    i think you can help me
    i have rotary axis with 0 to 360 degree
    and this rotary use +,- for direction rotation
    for exaple goes A10
    next goes A20 rotary turn 10 degrees
    next goes A40 rotary turn 20 degree
    if i want rotary goes to A20 i must write A-20!
    if i write A20 rotary turn 340 degree becuse i dont write +,- sign for true direction
    i dont know about change and edit pp and true code!
    thx
  1. Unknown milling machine - VECTOR?
    By MR_Rose in forum Drilling- and Milling Machines
    Last Post: 01-31-2020, 08:00 PM
  2. Vector programming for 5 axis
    By tomoboss1 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 06-10-2016, 03:29 AM
  3. g code - invert X axis after one pass...
    By dodman in forum G-Code Programing
    Last Post: 07-08-2013, 09:32 AM
  4. Table setup - Axis invert
    By horse in forum Uncategorised CAM Discussion
    Last Post: 02-28-2006, 03:45 PM
