586,069 active members*
3,425 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Help alarm 1100 Okuma
Results 1 to 3 of 3
    Alarm
    1100 Okuma lc30 osp300L
    Jun 2015
    4154
    Re: Help alarm 1100 Okuma
    hy, i can only help you with next error infos / kindly
    1100 Parameters not set
    The backup data caused an error and the factory-set initial data was forciby loaded. Machine data must be set again.
    [Object]
    None
    [Character-string]
    None
    [Code]
    XXXXYYYY
    XXXX
    bit 0:SPARE
    bit 1:HD backup status file
    bit 2:Low speed NC backup data file
    bit 3:High speed NC backup data file
    bit 4:PLC backup data file
    bit 5:PLC-HMI data file
    bit 6:Alarm history data file
    bit 7:PLC axis data file
    bit 8:POT TOOL data file(M/C only)
    bit 9:MOP TOOL data file(M/C only)
    bit10:MOP TOOL Parameter file(M/C only)
    YYYY
    1:File read open error
    2:File read error
    3:Version check error
    4:Check sum error
    5ouble check sum error
    6:Backup memory check error
    7:File write open error
    8:File write error
    Did you figure out your 1100 alarm? I have that one from time to time. Found that if I warm up machine that can help. Turn on machine (15 minutes) and then warm up spindle. Sometimes the 1100 will rest after turning the machine off, waiting a bit, then turning back on again. Other times you’ve blown one of the clearup fuses.
  1. okuma lr 15 cpu alarm
    By pedro pinto in forum Okuma
    Last Post: 03-24-2022, 02:28 AM
  2. okuma alarm 937
    By RINES in forum Okuma
    Last Post: 06-30-2021, 08:46 PM
  3. OKUMA LR-15 Alarm 202
    By Kenan5895 in forum Okuma
    Last Post: 08-15-2019, 06:48 AM
  4. 1019 ATC ALARM ON AKIRA SEIKE SV 1100
    By CNCdummie in forum USA Club House
    Last Post: 03-17-2018, 11:21 AM
