586,103 active members*
3,013 visitors online*
    Jul 2007
    6
    Ona Prima S900
    Hi people!!!
    I work with TopSolid'Wire and i need to understand how to control the 4 axis in the machine!!! in the NC program appears XY and UV!! it's possible appears the angle??
    Dec 2006
    131
    i am not really understanding the question. You are wanting to see the angle that the wire is positioned at? I know on the newer sodick controls you control the 4 axis with the following series of codes
    G140 turns the 4 axis off just like G40 turns cutter comp off
    G141 turns on 4 axis machining on with the wire on the left side of the feature.
    G142 turns on 4 axis machining on with the wire on the right side of the feature.
    maybe this helps a bit.
    Jul 2007
    6
    Smile ona prima s900
    Hi
    Thanks sodickappsguy for the information!!! yes it is...
    But is possible appears in NC program a variable for angle?? the real value of the angle??
