Hello! We have a milling machineKitamura H400 with control machine Fanuc 15, 5 axes of control with two interchangeable pallets.
We have lost all parameters of this milling machine.
Could anybody help us with table of parameters?
Your machine supplier should be able to advise. If not, Dan might be able to help you: https://www.practicalmachinist.com/v...ndrummerman21/
Did you find your parameters? I have a similar machine, all of the main parameters except the keep relay parameters. If you didn't find them, I can send what I have. If you did, can I get a list of the keep parameters?
Hello. Is the machine's problem solved?
Maybe I can help if you send me photos of model, label and machine.
+905357221418 whatsapp number
I just found this thread, was the problem solved? I have a backup of my H400 15m parameters. Can't guarantee everything is the same, but its a good start
