586,067 active members*
5,159 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > please help HQD GDL70-24Z/9.0 wiring diagram / instalation manual
    Nov 2012
    8
    Red face please help HQD GDL70-24Z/9.0 wiring diagram / instalation manual
    hi
    I purchased a chinese cnc router from an auction house,
    problem is it did not come with the spindle connector,
    i now have a new connector which i got from HQD directly, however they did not supply a wiring diagram and they wont answer any emails.
    the spindle is a HQD GDL70-24Z/9.0.
    can anyone supply the installation manual for this unit or a photo of the wiring going into the back of the connector and the inverter.
    below are some images of what i have.
    thanks in advance Mark
    Attachment 437164
    Attachment 437166
    Attachment 437168
    Attachment 437170
    Nov 2012
    8
    Re: please help HQD GDL70-24Z/9.0 wiring diagram / instalation manual
    ==for any one else that may need this info.==
    I have found a diagram from another Chinese manufacturer "Changsheng GDZ143X133-9" that looks identical to my spindle "HQD GDL70-24Z/9.0".
    Ive taken off the covers and using a multi meter traced the connections and they match the wiring diagram from the Changsheng spindle from what i can check.
    the only difference i can tell is that the bi metal switch which should show a connection between pin 1 and 5, but there is no connection in its cold state, perhaps the GDL70-24Z/9.0 is normally open when cold, to me this would make more sense.
    pin out diagram from the Changsheng GDZ143X133-9 first image below.
    pin out diagram on the left from the Changsheng GDZ143X133-9 with a picture on the right from my spindle GDL70-24Z/9.0.
    Attachment 437222
    hopefully a better picture of the GDL70-24Z/9.0
    Attachment 437228
    hopefully a better picture of the GDZ143X133-9
    Attachment 437226
    15362
    Quote Originally Posted by viso View Post
    Attachment 437222
    Attachment 437228
    Attachment 437226
    That looks to be how it should be wired, you can check with your meter the Ground PE main fat pins the other 3 will be U V W , the other connections you can check with the required voltage Fan Etc make sure the fan runs the correct direction
    Mactec54
  1. Replies: 3
    Last Post: 12-13-2017, 03:23 PM
  2. Enshu. DT Centre Wiring Diagram Manual
    By diamondyarn in forum Machinery Manuals / Brochures
    Last Post: 05-04-2015, 07:14 PM
  3. Dyna Myte 2400 manual+wiring diagram
    By ysihonda in forum Benchtop Machines
    Last Post: 02-26-2015, 09:25 PM
  4. Water chiller Cw3000 & CW5000 Manual and wiring diagram
    By Gweikelasers in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-03-2014, 08:15 AM
