586,469 active members*
3,130 visitors online*
IndustryArena Forum > Material Technology > Glass, Plastic and Stone > Feeds ans Rates on CNC with DSP controller
    Feb 2020
    hallo guys ,
    i am new in cnc world about 1 month
    i have cnc machine with dsp controller , trying cutting albond , acrylic and pvc..
    i have problems with acrylic (mostly 3mm thickness ) cutting . F.E. i have 4mm 1 flute end mill , i set 12500 rpm and 765 feed rate in vectric aspire , everything works fine with almond and pvc .
    but when i start cutting acrylic problems starts , if give to low workspeed from DSP controller it becomes gummy if high it brokes if something middle it jumping )))
    can anyone help me how solve this problem . i cant find anywhere what work speeds i should write in dsp
    Jun 2018
    362
    Re: Feeds ans Rates on CNC with DSP controller
    For acrylic:
    First: Use a cutter designed for it (single flute steep spiral) and run a single DoC at 20000-24000 RPM and about 1200 to 1500 mm/minute. Set the cut and RPM speeds in your G-Code and use the DSP speed reductions to find a good balance (between 60 to 90% works well for me).
    Second: Try a single flute router bit (not end-mill) at about 12000-16000 RPM at about 900 to 1200 mm/min. Taking two passes at about 90% DoC then the final 10% helps clear the mess.
    In both cases a compressed air stream into the cut makes a huge difference to cut and clean-up quality.
    To help avoid the jumping up, try a down-cut cutter but you will really need the air blast to help clear the chips. Alternately, use a vacuum or some other hold-down method such as double-sided tape.
    Other folks probably have some better ideas :-)
    Feb 2020
    thank you for ur time its very helpful for me
  1. Feeds and Speed and Plunge rates...
    By adam_m in forum DIY CNC Router Table Machines
    Last Post: 01-27-2014, 12:10 AM
  2. Need help with Speed rates and plunge rates
    By beise1m in forum DIY CNC Router Table Machines
    Last Post: 11-14-2012, 07:24 AM
  3. Specify G00 rates
    By CNC-Hammer in forum Okuma
    Last Post: 09-18-2008, 11:02 AM
  4. Feed Rates
    By rcheli in forum Benchtop Machines
    Last Post: 12-28-2005, 05:34 PM
