586,103 active members*
3,512 visitors online*
IndustryArena Forum > CNC Electronics > SmoothStepper Motion Control > Electronic newbie - what to include in ESS enclosure?
    Aug 2009
    119
    I'm totally inexperienced with electronics! I want to put an ESS in a stand alone enclosure, to connect with a G540 I put in my little Techno router. The router has been working just fine with Mach3 and the parallel port on my desktop, but I want to use it with a laptop.
    So my question is what do I really need to include in my enclosure. Seems like all I need is 1 ribbon with a db25 case mount, and a 5v wall wart, is that adequate? I've seen the commercial units with 3 db25 outputs, auxiliary RJ45, e-stop, Mean Well power supply, on/off switch.. My spindle is a small electric router, wouldn't mind turning that on and off with a relay, but I'm thinking I can do that with the G540.
    Apr 2007
    33
    Re: Electronic newbie - what to include in ESS enclosure?
    On the ESS you have 3 "db25" ports. Port 1 is the port for the parallel I/O for your G540. The others port 2 and 3 can be used for inputs or outputs depending upon which pin and which port. I have limited experience with the G540 but with it you are limited on your inputs and outputs for switches etc. And it does not use port 2 and port 3. On my machine I use a simple bob "break out board" to drive the signals to the stepper drivers and wire directly to the ESS with a 5V supply for my auto zero setup and limit switches. If you decide to use a laser or other tools ( tool changer) on your CNC these extra I/O pins can help so I would make allowances for them if nothing else but a screw terminal breakout board. I also use Mach3 so the software you are using might not be able to communicate with the other ports on the ESS.
    Good luck
    Doc
    Aug 2009
    119
    Thanks Doc
    I have no plans for this router other than using it as it is til I upgrade to a bigger machine
    I just discovered my power supply has a 5v out in addition to 36v, so I'm thinking I can use that to power the ESS.
  1. Electronic enclosure wiring to annotate
    By qwertysimo in forum CNC Machine Related Electronics
    Last Post: 11-01-2016, 12:20 PM
  2. Yet another CNC electronic enclosure wiring thread.
    By pilotarix in forum CNC Machine Related Electronics
    Last Post: 09-04-2016, 04:42 AM
  3. Anything I forgot to include for this enclosure
    By mioduz in forum Tormach Personal CNC Mill
    Last Post: 06-24-2014, 10:52 AM
  4. Things to include in an M06 macro
    By vandal968 in forum G-Code Programing
    Last Post: 05-08-2012, 07:14 PM
  5. Electronic enclosure
    By mikeschn in forum DIY CNC Router Table Machines
    Last Post: 01-09-2004, 07:53 PM
