586,121 active members*
3,184 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Using relay w/ G540 - 5v or 36v coil
    Aug 2009
    119
    New to electronics, and I want to use relays to turn on my router motor and dust collector. My power supply outputs 36v and 5v, wondering if there is any reason to get a relay with 5v coil or 36v coil?
    I'm looking at a T9AP1D52-36-01 relay, is this a good choice?
    Re: Using relay w/ G540 - 5v or 36v coil
    It looks to me like that relay would work. Stick with 36v if you have that power supply. Otherwise you end up like me with 4 different power supplies in my case.
    Aug 2009
    119
    Thanks for the reply.
    I actually have both 5v and 36v on the oem power supply of my Techno Davinci router, was just wondering if there was a reason to use one over the other,
    Mar 2007
    2083
    why not a 48V relay ?
    then you can use the G540's 48V supply
    what are you controlling with the relay ?
    John
    Aug 2009
    119
    I'm using 36v for the Gecko, could use that for the relays.
    Controlling router motor and dust collector
  1. G540, Relay Board and VFD
    By ZJGardner in forum Gecko Drives
    Last Post: 03-28-2020, 08:05 AM
  2. VFD P24 to G540 using a Relay
    By district7 in forum Spindles / VFD
    Last Post: 04-25-2015, 06:56 PM
  3. Relay coil Question
    By Bird_E in forum CNC Machine Related Electronics
    Last Post: 01-04-2010, 10:10 PM
  4. Gecko G540 Relay Help
    By The CNC Man in forum Stepper Motors / Drives
    Last Post: 12-03-2009, 11:11 PM
  5. G540 and cnc4pc C8 relay
    By blackrat in forum Gecko Drives
    Last Post: 04-22-2009, 03:03 PM
