586,659 active members*
3,765 visitors online*
Results 1 to 9 of 9
    Aug 2010
    130
    PathPilot V2.4.2 Release
    I was browsing the Tormach site and happened to notice the release of V2.4.2. I checked email and did not see a notice about the release. Did they stop notifying, or was it just me?
    I see that you can now GOTO a line and Set Start with no lead-in, or with a linear or plunge lead-in. The release notes give examples on that.
    Mar 2019
    34
    Re: PathPilot V2.4.2 Release
    No email here either however I have PP set to check for updates every time it starts up so I’ll find out one way or the other.
    Sent from my iPad using Tapatalk Pro
    Apr 2013
    1788
    I got a 2.4.2 announcement email earlier this morning.
    From the email:
    NEW KEY FUNCTIONALITY:
    • Slant PRO rapids are increased from 60 IPM to 100 IPM
    • An ADMIN ENCODER TEST procedure was added to support installation of the BT30 spindle upgrade for M+ machines
    • Massive improvement to the ‘SET START LINE’ functionality
    • Conversational pocketing has been reimplemented with improved cut strategies
    • Coolant and the spindle are no longer turned off and back on in between every shape in a DXF generated G-code file
    • USB stability is improved by disabling ‘power saving’ functionality
    • For complete release notes and more information on this version as well as feature suggestions and issue reporting visit the PathPilot Software Center.
    Mar 2019
    34
    Yup got the email today
    Oct 2005
    1145
    An important update was the peck rigid tapping . Great for a reduced HP spindle.
    (;-) TP
    Jan 2016
    99
    2 conversational modules I wish was on path pilot:
    radius mill, other than a circle or box with radius corners. either tangent to two edges or center point and degrees.
    The other is slot milling and starting from outside the part instead of the middle of the slot. This would help me not have to move the coolant or air blast in the middle.
    Or am I missing something already there?
    I am not real good at hand coding, especially multiple passes, and it is a pain to go back into the house and bring up cam for a simple job.
    Any one else miss these two options.
    Dave
    Jan 2016
    99
    everyone else must be using cam programs all the time not to miss those 2 conversational features.
    Dave
    Nov 2012
    591
    Yeah, pretty much. If I can't bang it out in 5 lines of G-code, it's off to Fusion I go!
    Nov 2007
    2151
    Quote Originally Posted by jwatte View Post
    About same here. I use conversation mostly for stock prep. Any more I tend to have what I'm working on in cad/cam. Then if I spot anything goofy. Its easy to stop the operation,walk back and make changes to cad / cam files and send revised code back ready to go.
  1. PathPilot 2.x and PathPilot Simulator
    By draper-ballou in forum Tormach PathPilot™
    Last Post: 01-01-2019, 01:42 AM
  2. Bad crash: Tool won't release, flashing release button
    By CrashTestDummy3 in forum Daewoo/Doosan
    Last Post: 04-04-2018, 02:38 PM
  3. Replies: 2
    Last Post: 12-03-2017, 12:02 AM
  4. PPD release in 3.5R2
    By fraesi in forum Uncategorised CAM Discussion
    Last Post: 12-06-2011, 09:50 PM
  5. New release?
    By harley4ever in forum Dolphin CAD/CAM
    Last Post: 03-06-2009, 03:50 AM
