586,108 active members*
3,100 visitors online*
Thread: G76 issue
    Feb 2006
    120
    G76 issue
    I am threading an 8-acme inside thread, I set the Q to 14, however the cut angle is much greater than that. probably closer to 20 or even as much as 25 degrees. when I cut a 60 degree thread and set the compound angle Q to 30 it works fine. has anyone else had this issue and may have a fix for it?
    this is the code:
    G76 P0.125 Z-3.0 I0.100 J0.008 K0.170 Q14 R1.5
    I plan on trying a Q7, but even if that works I would still like to understand the problem.
    thanks for your help.
    Ray,
    Life is a choice, death is choice poorly made.
    May 2008
    266
    Re: G76 issue
    I'm not running LinuxCNC myself, I'm using PlanetCNC which claims compatability with LinuxCNC.
    I copied & pasted your code into my controller and it looked good.
    Picture attached.
    Martin.
  1. Replies: 2
    Last Post: 08-25-2017, 07:55 PM
  2. Incoming Power Issue, or Transistor Issue
    By barchdesigns in forum CNC Machine Related Electronics
    Last Post: 08-19-2016, 10:32 PM
  3. Seems Z and A axis are not running...Motor issue or Step/Dir issue?
    By Cattle in forum Mach Software (ArtSoft software)
    Last Post: 04-12-2016, 08:51 PM
  4. Replies: 1
    Last Post: 01-08-2016, 06:58 AM
  5. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-07-2006, 09:19 PM
