586,035 active members*
3,712 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > Vision VE-810 engraver ..use without using dongle and vision proprietary software
Results 1 to 6 of 6
    Jul 2017
    348
    For anyone out there that has a vision ve-810 engraver without dongle or just dont like the limited vision software
    i discovered the machine can be used without dongle and vision software
    i used vectric aspire and sent toolpath directly to machine using a modified vision ve810 post processor
    it works very well
    Re: Vision VE-810 engraver ..use without using dongle and vision proprietary software
    Just saw this and I have the 810
    I use serial cable (com 4)
    I use aspire on my 4 x 4 router
    can you share how you modified PP
    and most importantly how you transmit the code to the machine
    Jul 2017
    348
    Do u have the vision dongle or no? If no you can use vectric aspire to create toolpath and send to vision engraver through vectric output toolpath to mschine option
    And the post proc u use drpends on your version of machine...i think my ve810 is v2 controller
    You would just add a printer to com4 and use windows generic printer text driver
    And the only thing i modified in the vectric stock vision driver are the remark lines before the prog starts..itcdoesnt like the remarks...faults out...so i removed them in the post and saved it
    If u give me ur email maybe i can email u the pp ...but i need to know ur vision version....post a pic of the front of machine
    ..that will help
    I have no idea which version control.
    I do have the dongle
    I never thought about doing this before, then I see your post and think, yes why not.
    i am not in a big hurry, but would like to explore my options.
    https://www.cnczone.com/forums/attac...1&d=1615841635
    Jul 2017
    Quote Originally Posted by Shelby5041 View Post
    ..that will help
    I have a VE810 S4
    Do you have a post processor for that version?
    Jul 2022
    it works very well
    Can you tell me exactly how you set this up?
    i get that you did a couple different things to make it work but could you send me a step by step on how you accomplished using the ve-810 without a dongle please?
    if you need any info from me, just let me know
    Thanks.
  1. Vision 2424 Engraver/Router Jog Speed
    By Picktool in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-17-2017, 02:43 AM
  2. Vision Engraver help / Repair needed
    By Toybreaker in forum Engraving Machines
    Last Post: 12-10-2014, 03:07 AM
  3. Help on DC speed control on vision max engraver
    By vger in forum Engraving Machines
    Last Post: 02-08-2013, 12:54 AM
  4. horizon (vision) engraver
    By dcumin in forum Engraving Machines
    Last Post: 05-25-2010, 09:07 PM
